The answer is yes ![]()
That’s pretty cool!!
That’s really cool! Thanks for posting!
Did you try to read out data from weatherstations with 433mhz for example? Can you control 433mhz powerplugs?
As the device has only one receiver and no emitter you can only receive infos.
I didn’t tested it with the weather stations compatibles with Pilight (you can add Pilight to Openmqttgateway) but in theory it should work.
