Thank’s!
found there a blog entry from David Graf
secret revealed…
MQTT Arrives in the Modern openHAB 2.x Architecture
Hello everyone
I went crazy all afternoon behind this problem, I can’t see the ON OFF payload on OH2, I use Mosquitto as a broker.
The card is a NODEMCU with Tasmota 11, I need it to read the status of an MQ2 sensor (digitally) to detect any gas leaks.
The sensor is connected to the GPIO2 as Switch1. With MQTT.fx I read the payload ON / OFF … then the broker reads the payload. But not OH.
ITEMS:
Switch sensore_caldaia "sensore caldaia " <sensore_fumo> (sensori) {mqtt="<[mosquitto:stat/locale_caldaia/SWITCH1:state:default]" }```
sitemap:
Switch item=sensore_caldaia
rule:
rule "sensore gas caldaia"
Item sensore_caldaia changed
if (sensore_caldaia.state == ON ){
Thread::sleep(3000)
if (sensore_caldaia.state == ON) {
postUpdate (ON)
playSound("RedAlert .mp3")
Thread::sleep(1000)
playSound("attenzione_fuga_di_gas_nel_locale_caldaia.mp3")
sendTelegram("bot1", "ALLARME LOCALE CALDAIA!")
if (sensore_caldaia.state == CLOSED && timer === null) {
timer = createTimer(now.plusMinutes(5)) [|
timer = null
postUpdate (OFF)
I ask you for help, thank you, sorry for the mistakes but I'm pretty tired
This is an rather old thread, you should have started a new onle for your problem!
Which MQTT binding are you using? The itme uses the Version 1 Syntax, confirm you are using this binding!
The syntax in your rule has several probems, solve those after the initial problem is cleared!
