in the same file as influxdb.persist
Is it possible to catalog the items in this way?
itemA: strategy = everyChange
itemB: strategy = everyMinute
itemC: strategy = everyHour
I can not find an example …
thank you
David
thank you
David
thanks
I did this:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
Items {
itemA : strategy = everyChange, everyMinute
itemB : strategy = everyHour
itemC : strategy = everyChange
but itemB and itemC do not work, while itemA works
If instead I put itemB and itemC together with itemA they work
what’s the reason?
Silly question but did you wait for 1 hour for itemB to be persisted?
And did itemC change?
Sometimes restarting openHAB helps.
restarted, it does not work
I modified the file last night and this morning I checked … neither item has changed
What are the items you are trying to persist, please?
I modified the strategy like this:
: strategy = everyChange, everyHour```
and now it works.
the item measures the health status of the home automation network peer
