I have some fibaro leak sensors that I use to turn off the water if a leak is detected. For some days now I have had problems with one sensor triggering even without a leak. So yesterday I removed the battery from the device to keep my wife happy. But this morning it happened again with the same sensor:
2017-08-10 07:00:55.822 [ItemStateChangedEvent ] - E1_Teknisk_Deteksjon_Lekkasjesensor_BinarySensor changed from OFF to ON
2017-08-10 07:00:55.822 [GroupItemStateChangedEvent] - dgLekkasje changed from OFF to ON through E1_Teknisk_Deteksjon_Lekkasjesensor_BinarySensor
The sensor is “E1_Teknisk_Deteksjon_Lekkasjesensor_BinarySensor”.
Anyone got any good ideas as to what is happening here? Why do I get false triggers of the sensor?
Here is a list of all triggers for the last 30 days:
I don’t think that this is related to your OH2 configs… One possibility is that the FGFS101 is simply reporting false positives.
check: Link
You can enable debug on the Z-Wave binding to see if the node is sending these false positive reports (or there is another source that triggers the ItemStateChangedEvent)
oops. i assumed that you re-inserted the battery
If it is offline, then the trigger isn’t coming from the Z-Wave binding (most likely)…
Do you have any kind of rule that updates the state of this item?
Is this item linked to any other binding (other than Z-Wave)
