OH uses something similiar to java, but not quite and hence I wonder what the syntax is to have item definition span over several lines in the editor. I have some long definitions:
Number Heating_BedRoom_Setpoint_Day (Group_Setpoint_Special,Group_SetPoint,Group_SetPoint_Special_PreHeat_Guests, Group_SetPoint_Special_Morning_Guests, Group_SetPoint_Special_Day_Guests,Group_BedRoom) .........
Which I would like to write like this:
Group_SetPoint,
If this is not possible I will update the documentation for items.
Number vBasement_RSSI "Basement Node Signal [%d]"
<network> (gChart, gResetExpire)
{mqtt="<[mosquitto:rfm69/uber_sensors/basement/rssi:state:default]", expire="5m"}
I know you can split up the { } across multiple lines but am not certain you can do the same for Groups. I have every reason to expect it will work. Try it and let us know.
