Deployed newest dockerized openhab version and configured everything via config files.
A minimal setup with
Paper UI,habpanel, rest docs
MQTT Thing with 2 Sonoff Things each with 6 channels
I can go into openhab ui and see the things with the channels not selected. If i click on the channel which seems to activate them they show up under the control slide. From there i can switch on and off the light.
I don’t have any access to the items entry which used to be below the Things entry in the menu. It’s gone.
I can add an item, see it with the rest docs but also this does not make the Item entry visible.
In Habpanel i do see the item but it does not work.
Any idea why
a) the items don’t show up?
b) the link does not work?
addons.cfg
The installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB
# Note: If you want to specify your add-ons yourself through entries below, set the package to "minimal"
# as otherwise your definition might be in conflict with what the installation package defines.
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other add-ons. Use this for custom setups.
# - simple : Setup for using openHAB purely through UIs - you need to expect MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from openHAB 1.x
# - demo : A demo setup which includes UIs, a few bindings, config files etc.
# See https://www.openhab.org/docs/configuration/packages.html for a detailed explanation of these packages.
package = minimal
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
#remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
#legacy = true
# A comma-separated list of bindings to install (e.g. "binding = sonos,knx,zwave")
binding = mqtt
# A comma-separated list of UIs to install (e.g. "ui = basic,paper")
ui = paper,habpanel,restdocs
# A comma-separated list of persistence services to install (e.g. "persistence = rrd4j,jpa")
#persistence =
# A comma-separated list of actions to install (e.g. "action = mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "transformation = map,jsonpath")
transformation = jsonpath
# A comma-separated list of voice services to install (e.g. "voice = marytts,freetts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "misc = myopenhab")
#misc =
Mqttbroker.things
Bridge mqtt:broker:MQTTBroker "MQTTBroker" [ host="mosquitto", secure=false,username="user",password="password",clientID="MQTTOpenHabID" ]
Thing topic Sonoff1 "Sonoff 1" @ "mytestlocation" {
Channels:
Type switch : switch "Power" [ stateTopic="LivingRoom/sonoff1/stat/POWER", commandTopic="LivingRoom/sonoff1/cmnd/POWER" ]
Type string : lwt "LWT" [stateTopic="LivingRoom/sonoff1/tele/LWT"]
Type number : uptime "UPTIME" [stateTopic="LivingRoom/sonoff1/tele/STATE",transformationPattern="JSONPATH:$.Uptime"]
Type number : rssi "RSSI" [stateTopic="LivingRoom/sonoff1/tele/STATE",transformationPattern="JSONPATH:$.Wifi.RSSI"]
Type number : vcc "VCC" [stateTopic="LivingRoom/sonoff1/tele/STATE",transformationPattern="JSONPATH:$.Vcc"]
Type string : version "VERSION" [stateTopic="LivingRoom/sonoff1/tele/INFO1",transformationPattern="JSONPATH:$.Version"]
Type string : ip "IP" [stateTopic="LivingRoom/sonoff1/tele/INFO2",transformationPattern="JSONPATH:$.IPAddress"]
Type string : WebServerMode "WebServerMode" [stateTopic="LivingRoom/sonoff1/tele/INFO2",transformationPattern="JSONPATH:$.WebServerMode"]
Type string : RestartReason "RestartReason" [stateTopic="LivingRoom/sonoff1/tele/INFO3",transformationPattern="JSONPATH:$.RestartReason"]
Thing mqtt:topic:Sonoff2 "Sonoff 2" @ "mytestlocation" {
Channels:
Type switch : switch "Power" [ stateTopic="LivingRoom/sonoff2/stat/POWER", commandTopic="LivingRoom/sonoff2/cmnd/POWER" ]
Type string : lwt "LWT" [stateTopic="LivingRoom/sonoff2/tele/LWT"]
Type number : uptime "UPTIME" [stateTopic="LivingRoom/sonoff2/tele/STATE",transformationPattern="JSONPATH:$.Uptime"]
Type number : rssi "RSSI" [stateTopic="LivingRoom/sonoff2/tele/STATE",transformationPattern="JSONPATH:$.Wifi.RSSI"]
Type number : vcc "VCC" [stateTopic="LivingRoom/sonoff2/tele/STATE",transformationPattern="JSONPATH:$.Vcc"]
Type string : version "VERSION" [stateTopic="LivingRoom/sonoff2/tele/INFO1",transformationPattern="JSONPATH:$.Version"]
Type string : ip "IP" [stateTopic="LivingRoom/sonoff2/tele/INFO2",transformationPattern="JSONPATH:$.IPAddress"]
Type string : WebServerMode "WebServerMode" [stateTopic="LivingRoom/sonoff2/tele/INFO2",transformationPattern="JSONPATH:$.WebServerMode"]
Type string : RestartReason "RestartReason" [stateTopic="LivingRoom/sonoff2/tele/INFO3",transformationPattern="JSONPATH:$.RestartReason"]
myItems.items
Switch SonOff1_Power "Ecklampe" {autoupdate="false",alexa="Switchable", channel="mqtt:topic:MQTTBrokerSonoff1:switch" }
