First time using openhabian and Im having a wierd problem where my DS18B20 temp sesnor works perfectly fine in the file system ‘/sys/bus/w1/devices/28-000000038880 $ cat w1_slave’ and I see temperature changes within seconds.
Thing config worked initially:
UID: onewiregpio:sensor:7ff8e7761a
label: Temperature Sensor
thingTypeUID: onewiregpio:sensor
configuration:
gpio_bus_file: /sys/bus/w1/devices/28-000000038880/w1_slave
refresh_time: 60
precision: 3
channels:
- id: temperature
channelTypeUID: onewiregpio:temperature
label: Temperature
description: Indicates the temperature read from one wire gpio sensor
configuration: {}
But when I go to the openhabian website, my item does not update at all. Its stuck at 24.63C.
It did work for about 12hours when I rebooted on fri night but it seems to freeze.
Also I’m trying to use Grafana and influx but everytime I reboot I have to run the openhabian-config and reinstall influx/grafana before grafana can talk to influxdb. I also have to redo my persisitance file. I set it up like this:
configurations:
- items:
strategies:
- everyChange
- everyMinute
filters: []
- items:
strategies:
- everyChange
- everyMinute
filters: []
cronStrategies:
- name: everyMinute
cronExpression: 0 * * * * ?
- name: everyHour
cronExpression: 0 0 * * * ?
- name: everyDay
cronExpression: 0 0 0 * * ?
defaultStrategies: []
thresholdFilters: []
timeFilters: []
equalsFilters: []
includeFilters: []
Is there something Im missing. Sorry Im new and was happy when my item worked through to Grafana but its no longer updating.
Everything is installed as per the raspberry PI SD card image and the standard openhabian options.
Thanks in advance.
Brett
- Platform information:
- Hardware: Raspberry pi 5
- OS: Openhabian
