Hi guys.
I’m applying the (very interesting) Presence Detection Tutorial.
All works fine so I’ve tried a system restart to evaluate the global status.
I’ve noticed that only the “System started” rules are (rightly) called when system reboot whereby the “Presence” proxy switch, normally updated by the “Presence_Sensors” rule, if a present sensor persists (for example “Sensor1Person1” item, pushed by a network binding …) remains in OFF state.
Is it true ?
Is this a weak point of the solution ?
Is the “Presence” Item to be declared as persistent ?
Thanks.
