I have a Problem with one of my rules, I think it is since the update to 2.2, but I am not absolutely sure. I have an item where I send a command to turn it off. I can see from the event log that the item receives an OFF and also my light goes off. However, another rule (maybe running on a different thread) which is executed 700ms after the event log says that my item received OFF still shows the state to be on.
Has there anything changed? Is there some synchronization/visibility problem?
Here an example from my logs:
openhab.log
2018-01-27 16:40:25.863 [INFO ] [ipse.smarthome.model.script.Abwesend] - Resetting EG_Gang LED group to 2 and turning off light as we are away
Immediately before logging this line I send execute this code: LED_EG_Gang_Switch.sendCommand(OFF)
events.log shows me that the item received this OFF command:
2018-01-27 16:40:25.873 [ome.event.ItemCommandEvent] - Item ‘LED_EG_Gang_Switch’ received command OFF
This is around 10ms after I sent it, this seems appropriate. However, I get the following afterwards:
openhab.log:
2018-01-27 16:40:26.588 [INFO ] [e.smarthome.model.script.Color Scene] - <Scene 1> <Led_Group2> Switch LED_EG_Gang_Switch is ON. Fading with item: LED_EG_Gang_RGB_Fading to color: 328,37,25
In this log message I use LED_EG_Gang_Switch.state and it evalutes to ON.
So to summarize:
2018-01-27 16:40:25.863: LED_EG_Gang_Switch.sendCommand(OFF)
2018-01-27 16:40:25.873: Item ‘LED_EG_Gang_Switch’ received command OFF
2018-01-27 16:40:26.588: LED_EG_Gang_Switch.state returns ON
Of course I checked the event log, the Switch was not turned ON before the state delivered ON. To me this definitely sounds like a bug. Any ideas?
Best regards,
Markus
