recently I noticed that items are no longer updated in time i.e. I’m facing a small delay.
Let me share a rule which I’m using to switch on a socket whenever it is switched off:
rule "Dunstabzug control"
Item Dunstabzug received command
var month = now.getMonthOfYear
logWarn("FILE", "Dunstabzug state 01: " + Dunstabzug.state)
//Thread::sleep(10)
if (month > 3 && month < 10 && Chimney.state!=ON) {
logWarn("FILE", "Dunstabzug state 02: " + Dunstabzug.state)
if (Dunstabzug.state==OFF || Dunstabzug.state==NULL) Dunstabzug.sendCommand(ON)
logWarn("FILE", "Dunstabzug state 03: " + Dunstabzug.state)
logWarn("FILE", "Dunstabzug state 04: " + Dunstabzug.state)
If I switch of Dunstabzug then I see the following in my openhab.log:
2017-09-02 11:50:21.105 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 01: OFF
2017-09-02 11:50:21.106 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 02: OFF
2017-09-02 11:50:21.107 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 03: OFF
2017-09-02 11:50:21.107 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 04: OFF
2017-09-02 11:50:21.126 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 01: ON
2017-09-02 11:50:21.129 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 02: ON
2017-09-02 11:50:21.129 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 03: ON
2017-09-02 11:50:21.130 [WARN ] [.eclipse.smarthome.model.script.FILE] - Dunstabzug state 04: ON
Seems to be there’s a delay until the state is updated. What’s the issue?
Thanks,
Manolo
P.S.: One more thing. If I uncomment the Thread Sleep of 10ms it is working fine.
There is no issue. It is working as designed and as expected.
It takes time for a sendCommand or postUpdate to go out the the event bus, be processed, and then have the Item reflect the new state. In your car is looks like it takes around 20 msec from the time you sendCommand until the rule triggers again so I would guess it takes around 10 msec on your state to get to the point where the item gets the new state.
OH is not a realtime system and sendCommand and postUpdate don’t just merely set a classes data member. Lots of processing goes on. The fact that it only takes 10 msec is really quite a miracle.
The conclusion though is if you need this sort of realtime restraints, OH is never going to live up to your needs.
You would have to look at the code over on ESH. From what I’ve seen of the architecture and the code, 300 commands is probably an order of magnitude too low for the number of commands that typically execute for a single sendCommand. Remember a sendCommand needs to:
be sent to the event bus
process through all the bindings/channels attached to that Item which can include going through transformations
kick off processing to update the state of all Groups it is a member of
save the new state to persistence
kick off any rules that are triggered by commands and updates to
It’s not just saving the new state. I admit I don’t know how much of the above takes place in parallel verses serial, but it is a lot of commands.
I don’t know what previous version of OH you are referring to, but if it is 1.8, the architecture of OH 2 is completely different and has to do a lot more than 1.8 used to which would account for the extra delay.
you’re right there are a lot of transaction linked to a sendCommand. I don’t know exactly which version didn’t cause this delay. Maybe I’ve to test one of the previous one. Could be that it was 2.0. Let me check and reply to this thread.
Thanks for your feedback.
Manolo
Well here we go. The rule was triggered at 1:17am and as you can see in openhab.log the status of Dunstabzug is always on even 800ms later.
Thanks, Manuel
My rules:
rule "All lights out"
Item Zentral_Licht_aus received command
if(receivedCommand==ON) {
logWarn("FILE","All lights on!!! Month "+month)
gLightAll.allMembers.forEach [ item | item.sendCommand(OFF) ]
gLightGuest.allMembers.forEach [ item | item.sendCommand(OFF) ]
gLightLiving.allMembers.forEach [ item | item.sendCommand(OFF) ]
if(Coming_Home.state==OFF) Licht_Haustuer.sendCommand(OFF)
if (now.getHourOfDay>20 || now.getHourOfDay<6) {
sendCommand(Taster_Luke, OFF)
sendCommand(Taster_Eltern, OFF)
sendCommand(Taster_Bad_OG, OFF)
sendCommand(Bad_West_Lamelle, 100)
sendCommand(Eltern_Sued_Lamelle, 100)
postUpdate(Zentral_Licht_aus, OFF)
Thread::sleep(500)
if (month > 3 && month < 11 && Chimney.state!=ON) {
Items config:
Group gLightAll "Zentral Licht" (All)
Group gLightGuest "Zentral Licht o. Gast" (All)
Group gLightLiving "Zentral Licht o. Wohnen" (All)
Switch Dunstabzug "Dunstabzug" (gEGController,gLightLiving) { knx="2/0/9" }
Switch Zentral_Licht_aus "Zentral Licht aus [(%s)]" <switch> (gScene) { knx="5/0/17" }
events.log (10 seconds):
2017-09-30 01:17:00.144 [ItemCommandEvent ] - Item 'Zentral_Licht_aus' received command ON
2017-09-30 01:17:00.145 [ItemCommandEvent ] - Item 'Steckdose_Server_KG' received command OFF
2017-09-30 01:17:00.164 [ItemStateChangedEvent ] - Zentral_Licht_aus changed from OFF to ON
2017-09-30 01:17:00.165 [ItemCommandEvent ] - Item 'Licht_Treppe_KG' received command OFF
2017-09-30 01:17:00.165 [ItemCommandEvent ] - Item 'Licht_kleines_Buero' received command OFF
2017-09-30 01:17:00.165 [ItemCommandEvent ] - Item 'Licht_Kinder' received command OFF
2017-09-30 01:17:00.166 [ItemCommandEvent ] - Item 'Licht_Leinwand_LED' received command OFF
2017-09-30 01:17:00.166 [ItemCommandEvent ] - Item 'Flur_OG_Hue' received command OFF
2017-09-30 01:17:00.166 [ItemCommandEvent ] - Item 'Licht_Haustuer' received command OFF
2017-09-30 01:17:00.167 [ItemCommandEvent ] - Item 'Licht_Podest_LED' received command OFF
2017-09-30 01:17:00.167 [ItemCommandEvent ] - Item 'Licht_Kino_dim' received command OFF
2017-09-30 01:17:00.167 [ItemCommandEvent ] - Item 'Licht_Kino_LW' received command OFF
2017-09-30 01:17:00.167 [ItemCommandEvent ] - Item 'Licht_Flur_KG' received command OFF
2017-09-30 01:17:00.167 [ItemCommandEvent ] - Item 'Licht_Abstellraum' received command OFF
2017-09-30 01:17:00.168 [ItemCommandEvent ] - Item 'Licht_WC_OG' received command OFF
2017-09-30 01:17:00.168 [ItemCommandEvent ] - Item 'Licht_Balkon' received command OFF
2017-09-30 01:17:00.168 [ItemCommandEvent ] - Item 'Licht_grosses_Buero' received command OFF
2017-09-30 01:17:00.168 [ItemCommandEvent ] - Item 'Licht_Ankleide' received command OFF
2017-09-30 01:17:00.169 [ItemCommandEvent ] - Item 'Downlight_Bad_OG_dim' received command OFF
2017-09-30 01:17:00.169 [ItemCommandEvent ] - Item 'Licht_Eltern' received command OFF
2017-09-30 01:17:00.169 [ItemCommandEvent ] - Item 'Licht_Bad' received command OFF
2017-09-30 01:17:00.169 [ItemCommandEvent ] - Item 'Licht_Garderobe' received command OFF
2017-09-30 01:17:00.170 [ItemCommandEvent ] - Item 'Licht_Garage' received command OFF
2017-09-30 01:17:00.170 [ItemCommandEvent ] - Item 'Licht_Nick' received command OFF
2017-09-30 01:17:00.170 [ItemCommandEvent ] - Item 'Licht_Luke' received command OFF
2017-09-30 01:17:00.170 [ItemCommandEvent ] - Item 'Downlight_Flur' received command OFF
2017-09-30 01:17:00.171 [ItemCommandEvent ] - Item 'Downlight_Bad_EG' received command OFF
2017-09-30 01:17:00.171 [ItemCommandEvent ] - Item 'Licht_Bad_EG' received command OFF
2017-09-30 01:17:00.172 [ItemCommandEvent ] - Item 'Licht_Gast' received command OFF
2017-09-30 01:17:00.172 [ItemCommandEvent ] - Item 'Stehlampe_EG_Hue' received command OFF
2017-09-30 01:17:00.172 [ItemCommandEvent ] - Item 'Downlight_Kamin_dim' received command OFF
2017-09-30 01:17:00.172 [ItemCommandEvent ] - Item 'Downlight_Essen_dim' received command OFF
2017-09-30 01:17:00.173 [ItemCommandEvent ] - Item 'Downlight_Kueche' received command OFF
2017-09-30 01:17:00.173 [ItemCommandEvent ] - Item 'Downlight_TV_dim' received command OFF
2017-09-30 01:17:00.173 [ItemCommandEvent ] - Item 'Licht_Vorrat' received command OFF
2017-09-30 01:17:00.173 [ItemCommandEvent ] - Item 'Esstisch_Hue' received command OFF
2017-09-30 01:17:00.174 [ItemCommandEvent ] - Item 'Licht_Kuechenschrank' received command OFF
2017-09-30 01:17:00.174 [ItemCommandEvent ] - Item 'Licht_Sofa' received command OFF
2017-09-30 01:17:00.174 [ItemCommandEvent ] - Item 'Dunstabzug' received command OFF
2017-09-30 01:17:00.175 [ItemCommandEvent ] - Item 'Licht_Treppe_OG' received command OFF
2017-09-30 01:17:00.175 [ItemCommandEvent ] - Item 'Licht_Gemaelde' received command OFF
2017-09-30 01:17:00.175 [ItemCommandEvent ] - Item 'Licht_TV' received command OFF
2017-09-30 01:17:00.175 [ItemCommandEvent ] - Item 'Licht_Haustuer' received command OFF
2017-09-30 01:17:00.176 [ItemCommandEvent ] - Item 'Taster_Eltern' received command OFF
2017-09-30 01:17:00.176 [ItemCommandEvent ] - Item 'Taster_Bad_OG' received command OFF
2017-09-30 01:17:00.176 [ItemCommandEvent ] - Item 'Bad_West_Lamelle' received command 100
2017-09-30 01:17:00.176 [ItemCommandEvent ] - Item 'Eltern_Sued_Lamelle' received command 100
2017-09-30 01:17:00.178 [ItemCommandEvent ] - Item 'Licht_Hue_Flur_3' received command OFF
2017-09-30 01:17:00.184 [ItemCommandEvent ] - Item 'Licht_Hue_Stehlampe_12' received command OFF
2017-09-30 01:17:00.198 [ItemCommandEvent ] - Item 'Light_Hue_Essen_Dim_4' received command 0
2017-09-30 01:17:00.210 [ItemCommandEvent ] - Item 'Light_Hue_Essen_Dim_5' received command 0
2017-09-30 01:17:00.380 [ItemCommandEvent ] - Item 'Sonos_Bad' received command OFF
2017-09-30 01:17:00.381 [ItemCommandEvent ] - Item 'Sonos_Bad' received command OFF
2017-09-30 01:17:00.384 [ItemCommandEvent ] - Item 'SonosWaterCtrl' received command PAUSE
2017-09-30 01:17:00.392 [ItemCommandEvent ] - Item 'SonosWaterCtrl' received command PAUSE
2017-09-30 01:17:01.400 [GroupItemStateChangedEvent] - gTasterOG changed from ON to OFF through Taster_Bad_OG
2017-09-30 01:17:01.463 [ItemStateChangedEvent ] - Zentral_Licht_aus changed from ON to OFF
2017-09-30 01:17:01.485 [ItemStateChangedEvent ] - Azimuth changed from 357.21 to 357.55
2017-09-30 01:17:01.485 [ItemStateChangedEvent ] - Elevation changed from -41.39 to -41.40
2017-09-30 01:17:02.363 [ItemStateChangedEvent ] - Dunstabzug changed from ON to OFF
2017-09-30 01:17:02.488 [ItemStateChangedEvent ] - Taster_Bad_OG changed from ON to OFF
2017-09-30 01:17:10.076 [ItemStateChangedEvent ] - Power_Daily changed from 494 to 500
2017-09-30 01:17:10.076 [ItemStateChangedEvent ] - Power_Weekly changed from 75268 to 75274
20
