- Platform information:
- Hardware: RPi3
- openHAB version: migration from OH2.4 to OH3.1
- Issue of the topic: Item status values not correct when used in rules in OH3.1
I’m migrating my OH2.4 setup to OH3.1 but I have an issue with some of my rules. When I use item states in my rules these values are not always correct in the output of the rule.
When one of my items received a command, the rule triggers and send a MQTT message which include the state of the item.
This works fine in OH2.4 but isn’t working well in OH3.1.
In OH3.1 the send MQTT messages includes most of the time the old/previous item state and not the new one. This is verry annoying
For example when I change my item Dimmer Allegretto_zone1_vol via the app or basic UI from value 20 to value 70 then in OH2.4 a MQTT message with value 70 is send. But in OH3.1 this MQTT message contains the value 20 (the old/previous value). When I then change the value from 70 to 50 the send value in OH3.1 is 70 and not 50!
See my items and rules below:
Items:
Dimmer Allegretto_zone1_vol "music zone 1 volume [%d %%]"
Switch Allegretto_zone1_mute "music zone 1 on/off"
Rules in OH2.4:
Rule to change the volume:
rule "volume zone 1"
Item Allegretto_zone1_vol received command
var VOL = (Allegretto_zone1_vol.state as Number).intValue
if (VOL == 100){
VOL = VOL - 1
Allegretto_MQTT_command.sendCommand("*VOL,99,99,1,2," + String::format("%02d",VOL) + ";")
Rule to mute:
rule "mute zone 1"
Item Allegretto_zone1_mute received command
if (Allegretto_zone1_mute.state == ON) Allegretto_MQTT_command.sendCommand("*MUT,99,99,1,0,00;")
else if (Allegretto_zone1_mute.state == OFF) Allegretto_MQTT_command.sendCommand("*MUT,99,99,1,1,00;")
Rules in OH3.1:
if (VOL == 100){
VOL = VOL - 1
val mqttActions = getActions("mqtt","mqtt:broker:MQTTbroker")
mqttActions.publishMQTT("Allegretto/Commando", "*VOL,99,99,1,2," + String::format("%02d",VOL) + ";")
Rule to mute:
rule "mute zone 1"
if (Allegretto_zone1_mute.state == ON){
mqttActions.publishMQTT("Allegretto/Command", "*MUT,99,99,1,0,00;")
else if (Allegretto_zone1_mute.state == OFF){
mqttActions.publishMQTT("Allegretto/Command", "*MUT,99,99,1,1,00;")
What is the issue here?
