Suggsy
(Suggsy Blackburn)
February 25, 2021, 8:01pm
#1
Hi all just transferred over to OH 3, loving it so far, a quick question.
What is my best approach?
When contact 1 changes state from closed to open light A comes on for 5 minutes then Light A goes off.
Just a pointer into the right direction would be appreciated.
rlkoshak
(Rich Koshak)
February 25, 2021, 8:17pm
#2
The best approach would be the same as it was in OH 2.5.
You can configure Expire (which is part of core instead of a separate binding now) by setting metadata on the light Item so it turns off after 5 minutes.
Or you can write a rule with a Timer.
Suggsy
(Suggsy Blackburn)
February 25, 2021, 8:22pm
#3
Thanks for the reply, I’ve used the expire which works great but I also would like light to be switchable.
What would be the syntax be for using a timer within a rule
