Hello everyone,
I am using an XB3-24Z8PT-J as a bridge to connect to the BASICZBR3 switch, I detect it successfully and it is online, then I add a switch item to the provided channel:
15:50:26.352 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:f3dc8e65fc:00124b00226cad76' changed from ONLINE to UNKNOWN
15:50:26.359 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Coordinator is ONLINE. Starting device initialisation.
15:50:26.377 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Start initialising ZigBee Thing handler
15:50:26.379 [DEBUG] [iscovery.ZigBeeNodePropertyDiscoverer] - 00124B00226CAD76: ZigBee node property discovery start
15:50:26.384 [DEBUG] [iscovery.ZigBeeNodePropertyDiscoverer] - 00124B00226CAD76: ZigBee node property discovery using basic cluster on endpoint D424/1
15:50:56.617 [DEBUG] [iscovery.ZigBeeNodePropertyDiscoverer] - 00124B00226CAD76: Stack version failed
15:50:56.617 [DEBUG] [iscovery.ZigBeeNodePropertyDiscoverer] - 00124B00226CAD76: Node doesn't support OTA cluster
15:50:56.617 [DEBUG] [iscovery.ZigBeeNodePropertyDiscoverer] - 00124B00226CAD76: ZigBee node property discovery complete: {zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x0000, modelId=BASICZBR3, zigbee_networkaddress=54308, zigbee_powersource=MAINS, zigbee_datecode=20201026, zigbee_zclversion=1, vendor=SONOFF, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=1, zigbee_applicationVersion=4, zigbee_device_initialised=true}
15:50:56.626 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Checking endpoint 1 channels
15:50:56.627 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Dynamically created 1 channels
15:50:56.627 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Device initialization will be skipped as the device is already initialized 15:51:06.381 [DEBUG] [converter.config.ZclOnOffSwitchConfig] - D424/1: Unable to get supported attributes for On/Off
15:51:25.862 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Channel initialisation complete
15:51:25.862 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Setting ONLINE/OFFLINE timeout interval to: 1830
15:51:25.868 [DEBUG] [g.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker added for thingUID=zigbee:device:f3dc8e65fc:00124b00226cad76
15:51:25.868 [DEBUG] [g.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:f3dc8e65fc:00124b00226cad76
15:51:25.873 [DEBUG] [g.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:f3dc8e65fc:00124b00226cad76 in 1830 seconds
15:51:35.593 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Error getting binding table
15:51:35.593 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Polling initialised at 986070ms
15:51:35.593 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:f3dc8e65fc:00124b00226cad76' changed from UNKNOWN to ONLINE
15:51:35.599 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Done initialising ZigBee Thing handler
15:51:35.878 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B00226CAD76: ZigBee saving network state complete.
Given the channel is also online, when I toggle the item values OFF and ON nothing happens with the switch and the thing representing it goes offline, here are the logs:
16:17:38.892 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Lamp_MAINSPOWEROUTLETSwitch' received command ON
16:17:38.895 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'Lamp_MAINSPOWEROUTLETSwitch' predicted to become ON 16:17:38.895 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Command for channel zigbee:device:f3dc8e65fc:00124b00226cad76:00124B00226CAD76_1_switch --> ON [OnOffType]
16:17:38.901 [DEBUG] [.converter.ZigBeeBaseChannelConverter] - 00124B00226CAD76: Channel zigbee:device:f3dc8e65fc:00124b00226cad76:00124B00226CAD76_1_switch waiting for response to ON
16:17:38.907 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Lamp_MAINSPOWEROUTLETSwitch' changed from NULL to ON 16:17:46.080 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Lamp_MAINSPOWEROUTLETSwitch' received command OFF
16:17:46.081 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'Lamp_MAINSPOWEROUTLETSwitch' predicted to become OFF 16:17:46.083 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00226CAD76: Command for channel zigbee:device:f3dc8e65fc:00124b00226cad76:00124B00226CAD76_1_switch --> OFF [OnOffType]
16:17:46.084 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Lamp_MAINSPOWEROUTLETSwitch' changed from ON to OFF 16:17:46.091 [DEBUG] [.converter.ZigBeeBaseChannelConverter] - 00124B00226CAD76: Channel zigbee:device:f3dc8e65fc:00124b00226cad76:00124B00226CAD76_1_switch waiting for response to OFF
16:17:48.646 [DEBUG] [.converter.ZigBeeBaseChannelConverter] - 00124B00226CAD76: Channel zigbee:device:f3dc8e65fc:00124b00226cad76:00124B00226CAD76_1_switch received TIMEOUT in response to ON
16:17:48.652 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:f3dc8e65fc:00124b00226cad76' changed from ONLINE to OFFLINE 16:17:58.361 [DEBUG] [.converter.ZigBeeBaseChannelConverter] - 00124B00226CAD76: Channel zigbee:device:f3dc8e65fc:00124b00226cad76:00124B00226CAD76_1_switch received TIMEOUT in response to OFF
I still can turn the physical switch ON and OFF, its just the issue with the remote control.
Thank you!
cheers
