I run my openHAB on a raspberry 3B+. I use Raspberry OS (I have also pihole running on it. pi hole does not run on openhabian).
Everything is set up, I created a simple sitemap, and made a binding with my Fritz Box, where a DECT Thermostat is connected. I added the thing with the Paper UI.
Now I am just palying around to get to know the platfrom. But now my problem: if I create an item with the Paper UI and integrate this into the sitemap, everything runs smoothly. But if I create an item with Visual Code, the item cannot be found with the Paper UI and in the sitemap, the values are not shown.
//Item created and copied from PaperUI => works
Number HeizungArbeitszimmer_CurrentTemperature "Heizung Arbeitszimmer" <heating> (Arbeitszimmer) {channel=avmfritz:Comet_DECT:192_168_178_21:133570399248:temperature}
//Test item created with Visual Code (with the plugin and connected to the Raspberry) => No link or item in PaperUI. Entry shown in Basic UI, but no value
Number Temperature_ComfortTemp "Comfort temperature" {channel=avmfritz:Comet_DECT:192_168_178_21:133570399248:comfort_temp}
I checekd the .items file on the raspberry and indeed has the same content as the Visual Code file.
Below the image from the Basic UI.
As soon as I create the item with the name âTemperature_ComfortTempâ
Your openhab.log probably offers clues.
When the file watcher notices a new/updated xxx.items file in the correct folder, it will announce itâs going to load it there.
If thereâs something wrong with your syntax, it usually, says so.
If a UI tries to fetch an Item, that doesnât exist, thereâll be a message about that.
The log is full of
2020-11-08 07:59:44.849 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âTemperature_ComfortTempâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Setpoint
The same is true for the other items. I also cleared the chache.
That means the Item doesnât exist as far as openHAB is concerned. Is this one you tried to create via files? When you save the items file, do you get confirmation in the logs that the Items have been processed?
That doesnât matter - you can have more than one Item attached to the same Channel. However, you shouldnât make two identical Items, one via files, and one via PaperUI, because that wonât work. Not saying you have done that, just an FYI.
okay. wired. I moved the itmes that casued problems in an own .items file and suddenly it worksâŠI hope I don`t have to do this with all thingsâŠotherwise there might be a lot of items files
not really. The first 2 items worked. The second set of three icons not. Copying the second set in a new items-file and leaving the first two in the orignal file solved the problem. I did not change the syntax or the file extension. Anyway. Thanks for your help
But since I am a absolute beginner, I admit magic is just stuff we don`t fully understand;)
The syntax in your .items file is incorrect in which case you should see errors in openhab.log when the file is loaded.
Youâve recently cleared the cache. There is a known problem where Items disappear after clearning the cache. You should wait for OH to come up, then reboot. That should clear things up.
Note, hafniumzincâs suggestion is good as well. The quotes around the channel ID is required.
The fact that copying the Items to a new file indicates that 2 was probably the original problem.
