Karl1
(Karl Misslik)
January 31, 2022, 9:34am
#1
Platform information:
Hardware: RASPI4B 4 GB
OS: openhabian 1.7
Java Runtime Environment:
openHAB version: 3.2
My configuration is :
Model modelled in Main UI
Items modelled in .Item Files.
After a reboot all my items now “out” of the model ( at the end of the list in the Main UI)
I tried the following and could fix it :
I renamed all items in each file and saved it again.
After that the connection to the model was established again.
But i like to understand this deeper.
Everytime after reboot to rename all items is …
I know that the model is organized as a bunch of structured group items.
Is it better when i have the items in “.item” files also to do the same with the model
and have it in a file like “model.items” as textual configuration and not add it via Main UI to the database ?
Do such a group item have a “special” ID to identify it as member of the model ?
You should not mix UI and *.items files when it comes to the Semantic model - results are unpredictable.
If you want to maintain the *.items files then you will have to put all the Semantic model stuff into *.items files too . Make sure to delete the UI-generated Items first!
Note the last paragraph in the linked forum post:
If part of the Semantic Model was defined and created using the UI you may find that your stuff has lost its position in the model after a restart of openHAB. Recommend that it’s either all UI, or all configuration files, but not a mixture, to reduce unpredictability!
rossko57
(Rossko57)
January 31, 2022, 10:53am
#3
Yes. Add the semantic tags to your items in file, by hand.
Karl1
(Karl Misslik)
January 31, 2022, 11:07am
#4
Thanks for the quick advice
mstormi
(Markus Storm)
January 31, 2022, 1:02pm
#5
@Karl1 you should not mix config via UI and files at all . It’s complex and not recommended - when you do, you’re basically asking for trouble (also beyond the semantic model).
