From one i set the switch to on .
And before updating , when i went to the second tab which is the same basic ui, the switch was toggled ON with 1sec delay more or less.
Since i updated nothing happen, and if i refresh the page, the switch come back to OFF.
i did not change anything on my conf folder. the only thing i did is to update oh2 and the main problem was with changes from mapdb to jsondb i think (in the previous post @sihui told me that) i had to reinstall binding but not everything is alright on the binding side.
In the event log i have the correct events :
2016-12-22 15:23:37.866 [ItemCommandEvent ] - Item ‘Light_GF_Kitchen_Ceiling’ received command ON
2016-12-22 15:23:40.151 [ItemCommandEvent ] - Item ‘Light_GF_Kitchen_Ceiling’ received command OFF
but nothing is changing ono the second basic ui opened.
has anyone had the problem?
Thanks a lot and thanks for the community for the work done on OH.
B.R
edit: i was thinkin about a problem with SSE but even if i refresh page , all switches stay at OFF position even if i switch them ON , so perhaps there’s a problem with SSE but there’s another problem with states…
I did a fresh install from apt-get (offline distro) , i copied only conf folder and same issue.
Behind there is knx 1.9 which was working like a charm before the update. Sse is the server send event implemented in oh2 no?
Is it possible that it’s a persistence issue ?
Edit: I will try to find out how to debug that switch , the problem occur on every switch
Edit2: but before binding with knx at first when I started using oh I made my config without any knx binding and the switch where working, so if I have time i will try another fresh install and make new conf by copying the content and see if it’s working
ssh openhab@localhost -p 8101
Password is habopen log:set DEBUG org.openhab.binding.knx
to go back to normal logging: log:set INFO org.openhab.binding.knx
Thanks ,
but finally i installed a fresh version and i just edit my conf files and everything is now good again so perhaps something in my files were wrong… don’t know…
but i have now an other issue i will create a new thread soon about it .
