my items seem to not be fully initialized when the rules are executed.
After starting up Openhab2, when my rules are executed, I get ‘item x cannot be found’ error messages.
Which item can’t be found varies from time to time.
The problem is that the respecting rule with the error stops working completely.
Interestingly, when I then edit the rules file and do a dummy change, the rules file is refreshed and the rules start working properly.
It seems that the rules are executed at an too early stage. I do not use system startup rules, my rules are only triggered on item changes or by cron pattern.
I use Openhab2 beta 3, but I had the same behaviour in older snapshots.
Same problem here also for ‘System started’ rules.
Any advices so far?
Thanks!
Some logs:
Caused by ‘System started’ rule
2016-09-04 10:19:47.397 [INFO ] [ome.core.thing.internal.ThingManager] - Not delegating update 'ALLSENS_ARMED' for item 'SIRENE_ARM_STATE' to handler for channel 'homematic:HM-Sec-Sir-WM:92859b7c:NEQ0510649:4#ARMSTATE', because thing is not initialized (must be in status ONLINE or OFFLINE).
Caused by executing the rule a way too early (implicit triggered by a System started rule):
2016-09-04 10:19:47.357 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'my rule': An error occured during the script execution: The name 'sendBroadcastNotification(<XStringLiteralImpl>)' cannot be resolved to an item or type.
