I have a string Item, containing the TV channel to send to my TV.
Format is 401 or 5001
I would like to use a structure like For Each on all single digit of the string, and then send command
Inside the For Each cycle i need to put the single digit into a string variable.
I’m looking around on the forum but I’m stuck on this from a couple of days.
If you run into trouble with your Rules stopping working, you will need to adjust this Rule to use Timers instead of Thread::sleep. As it is, a four character long command will keep this Rule running for more than two seconds.
