Widget (including rules and thing) for the Itho Daalderop Ventilation WiFi addon. It shows fan speed, humidity and (optionally) CO2 levels. It also responds to the remote of the fan. Furthermore it can be used to control it, by using the buttons (four match the remote, one is for a custom level). The rule automatically sets a day and night setting and switches to a high setting when humidity or CO2 becomes high (f.i. while showering or cooking). It’s intended/ designed for a phone page or a tile on a gridlayout dashboard.
Installation
The widget requires a some things to work that can’t be installed automatically. Detailed instructions (and manual) can be found in my github project. In short:
- Install the java scripting engine.
- Create a new rule, move to code tab and replace content with the timertick rule.
- Create a new rule, move to code tab and replace content with the fan rule.
Screenshots
Changelog
Version 1.21
- fixed: if you use the rule, fix for openHab 4.0/4.01
Version 1.2
- added : (optional) CO2 sensor/icon to widget
- added : (optional) VOC sensor/icon to widget
- added : (optional) home/presence item to widget
- added : day is split in morning, afternoon and evening
- added : (optional) smoothing of CO2/VOC adjustments
- fixed: button remained lit when pressed just at the moment the rule ran
- fixed: detection of manual input by remote/widget/add-on GUI
- fixed: layout on mobile screens
- fixed: openHAB Marketplace bug (replaced all default props with formula)
Version 1.1
- added : humidity sensor/icon to widget
- added : show remaining time of timers
- added : modified automation rule to respond to humidity
Version 1.0
- fixed: layout
- fixed: delay in button highlighting
- added: automation rule
Version 0.1
- initial release of widget
Resources
https://raw.githubusercontent.com/supersjellie/openhab-itho-fan/main/widget/widget.yaml
