- Platform information:
- Hardware: Mini ITX AMD-E350 4GbRAM 60Gb HD
- OS: Debian 9
- Java Runtime Environment: openjdk version “1.8.0_181”
OpenJDK Runtime Environment (build 1.8.0_181-8u181-b13-2~deb9u1-b13)
OpenJDK 64-Bit Server VM (build 25.181-b13, mixed mode) - openHAB version: 2.4
I recently made some changes to mqtt-eventbus.cfg, mqtt.cfg and set up mail.cfg which seems to have resulted in a meltdown/runaway item update situation whereby hundreds of events were appearing in tail -f /var/log/openhab2/openhab.log /var/log/openhab2/events.log. Rather concerned I then backed out all the changes, rebooted and managed to stabilise the situation.
I then updated Openhab and Debian V9 O/S.
However, I now have REST API issues (i think).
My Node-Red nodes are updating weather items happily but I keep getting the following;
The errors then clear on next update and correct values appear, then it repeats etc etc. I also now have “Offline: waiting for connection to become available” appearing (then disappearing) in Basic UI (Chrome on Win10)
Syslog entry:
roller:Openhab] Requesting URI http://openhab:(mypsswd)@192.168.1.202:8080/rest/items/ with method GET
Jan 1 11:57:42 Openhab Node-RED[5264]: 1 Jan 11:57:42 - [info] [openhab-v2-controller:Openhab] Event {
Jan 1 11:57:42 Openhab Node-RED[5264]: type: Error: connection ended
Jan 1 11:57:42 Openhab Node-RED[5264]: at IncomingMessage.<anonymous> (/home/openhab/.node-red/node_modules/@joeybaker/eventsource/lib/eventsource
.js:133:28)
Jan 1 11:57:42 Openhab Node-RED[5264]: at emitNone (events.js:111:20)
Jan 1 11:57:42 Openhab Node-RED[5264]: at IncomingMessage.emit (events.js:208:7)
Jan 1 11:57:42 Openhab Node-RED[5264]: at endReadableNT (_stream_readable.js:1064:12)
Jan 1 11:57:42 Openhab Node-RED[5264]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
Jan 1 11:57:42 Openhab Node-RED[5264]: at process._tickCallback (internal/process/next_tick.js:181:9) }
I’m pressing on trying to find root cause but any ideas would be appreciated.
Cheers
Chris
