Platform information:
- Hardware: synlogy
- OS: docker
- Java Runtime Environment: the one provided in the docker image
- openHAB version: 3.0.1
Issue of the topic:
- I’ve added zwave debugging with LOG Level DEBUG to mit lg4j config and restarted the docker container afterwards. (ZWave - Bindings | openHAB)
Pages and sitemap still show items and also points, however the list of things is empty and shows “0” items - please add items using bindings
my wave logfile is also empty even though events.log shows mulitple events with ItemChanged from my Zwave Things …
Please post configurations (if applicable):
- Items configuration related to the issue - n/a
- Sitemap configuration related to the issue - n/a
- Rules code related to the issue - none
- Services configuration related to the issue - n/a
If logs where generated please post these here using code fences:
events.log
2021-03-16 07:58:43.235 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_CleaningDuration' changed from NULL to 49.0
2021-03-16 07:58:44.425 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KucheThermostat_Sensortemperature' changed from NULL to 18.57 °C
2021-03-16 07:58:44.426 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_target' changed from NULL to 20.0 °C
2021-03-16 07:58:44.427 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Vibration' changed from NULL to ON
2021-03-16 07:58:44.431 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Kontakt' changed from NULL to CLOSED
2021-03-16 07:58:44.485 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_Cleaning_Last_Clean_Area' changed from NULL to 43.845
2021-03-16 07:58:44.788 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'varAutomatisierungFlur' changed from NULL to ON
2021-03-16 07:58:45.277 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SpotifyPlayerBridge_Lautstarke' changed from NULL to 100
2021-03-16 07:58:45.494 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Batterieladung' changed from NULL to 98.0
2021-03-16 07:58:45.928 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_Helligkeit' changed from NULL to 662.0
2021-03-16 07:58:46.194 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_Sensortemperature' changed from NULL to 19.8 °C
2021-03-16 07:58:46.385 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 07:58:46.397 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Temperatur' changed from NULL to 21.3 °C
2021-03-16 07:58:46.447 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become NULL
2021-03-16 07:58:46.461 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 07:58:46.464 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become NULL
2021-03-16 07:58:46.559 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_StatusLEDaus' changed from NULL to OFF
2021-03-16 07:58:46.741 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurRoomHue_Farbe' changed from NULL to 0,0,0
2021-03-16 07:58:46.872 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_Sensorluminance' changed from NULL to 0.0
2021-03-16 07:58:47.182 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachAktuell_Luftdruck' changed from NULL to 1023.0 hPa
2021-03-16 07:58:47.561 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_StatusLEDaus' changed from NULL to ON
2021-03-16 07:58:48.031 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'farbigeLampenZoneHue_Helligkeit' changed from NULL to 0
2021-03-16 07:58:48.256 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_NiedrigerBatteriestatus' changed from NULL to OFF
2021-03-16 07:58:48.429 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerRoomHue_Schalter' changed from NULL to OFF
2021-03-16 07:58:48.630 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'varAutomatisierungBadezimmer' changed from NULL to OFF
2021-03-16 07:58:48.842 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad2Thermostat_OpennessOfTheValve' changed from NULL to 0
2021-03-16 07:58:49.017 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TischRoomHue_Farbtemperatur' changed from NULL to 61
2021-03-16 07:58:49.386 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Batterieladung' changed from NULL to 99.0
2021-03-16 07:58:49.691 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_Status_Clean_Area' changed from NULL to 43.845
2021-03-16 07:58:50.026 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_NiedrigerBatteriestatus' changed from NULL to OFF
2021-03-16 07:58:50.244 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_Batterieladung' changed from NULL to 100.0
2021-03-16 07:58:50.419 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SteckdoseKuechenlicht_Switch' changed from NULL to ON
2021-03-16 07:58:50.652 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerThermostat_Setpointheating' changed from NULL to 20.0 °C
2021-03-16 07:58:50.803 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachAktuell_Schnee' changed from NULL to 0.0 m
2021-03-16 07:58:51.130 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_Temperatur' changed from NULL to 26.9 °C
2021-03-16 07:58:51.273 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Huego1Hue_Farbtemperatur' changed from NULL to 52
2021-03-16 07:58:51.575 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Offnungswinkel' changed from NULL to 0.0 °
2021-03-16 07:58:51.652 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'weisseLampenZoneHue_Schalter' changed from NULL to OFF
2021-03-16 07:58:51.810 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_TotalCleaningArea' changed from NULL to 552.8725
2021-03-16 07:58:51.946 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Signalstarke' changed from NULL to 3.0
2021-03-16 07:58:52.150 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_MotionAlarm' changed from NULL to OFF
2021-03-16 07:58:52.501 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SpotifyGalaxyS10Benedict_Lautstarke' changed from NULL to 100
2021-03-16 07:58:52.503 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_WaterBoxState' changed from NULL to OFF
2021-03-16 07:58:52.738 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerThermostat_Sensortemperature' changed from NULL to 17.35 °C
2021-03-16 07:58:52.976 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad2Thermostat_TemperatureforHeatComfort' changed from NULL to 15.0 °C
2021-03-16 07:58:53.120 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachAktuell_Regen' changed from NULL to 0.0 m
2021-03-16 07:58:53.250 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'varAutomatisierungSchlafzimmer' changed from NULL to OFF
2021-03-16 07:58:53.375 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'farbigeLampenZoneHue_Schalter' changed from NULL to OFF
2021-03-16 07:58:53.502 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Temperatur' changed from NULL to 19.2 °C
2021-03-16 07:58:53.694 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurRoomHue_Schalter' changed from NULL to OFF
2021-03-16 07:58:53.980 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerRoomHue_Helligkeit' changed from NULL to 0
2021-03-16 07:58:54.101 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerThermostat_Sensortemperature' changed from NULL to 17.41 °C
2021-03-16 07:58:54.386 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'varAutomatisierungArbeitszimmer' changed from NULL to ON
2021-03-16 07:58:54.449 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'varAutomatisierungWohnzimmer' changed from NULL to ON
2021-03-16 07:58:54.513 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 07:58:54.522 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become NULL
2021-03-16 07:58:54.537 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurBadRoomHue_Farbe' changed from NULL to 0,0,0
2021-03-16 07:58:54.550 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'weisseLampenZoneHue_Farbtemperatur' changed from NULL to 0
2021-03-16 07:58:54.565 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Signalstarke' changed from NULL to 4.0
2021-03-16 07:58:54.659 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SteckdoseKuechenlicht_Electricmetervolts' changed from NULL to 230.8
2021-03-16 07:58:54.748 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 07:58:54.756 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 07:58:55.025 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_StatusLEDaus' changed from NULL to ON
2021-03-16 07:58:55.141 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurBadRoomHue_Schalter' changed from NULL to OFF
2021-03-16 07:58:55.411 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadezimmerThermostat_Sensortemperature' changed from NULL to 19.71 °C
2021-03-16 07:58:55.629 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerRoomHue_Farbe' changed from NULL to 0,0,0
2021-03-16 07:58:55.796 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerThermostat_Batterieladung' changed from NULL to 68.0
2021-03-16 07:58:55.833 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_FanPower' changed from NULL to 102.0
2021-03-16 07:58:56.001 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad2Thermostat_Batterieladung' changed from NULL to 100.0
2021-03-16 07:58:56.065 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ArbeitszimmerThermostat_Batterieladung' changed from NULL to 63.0
2021-03-16 07:58:56.264 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadezimmerThermostat_Setpointheating' changed from NULL to 10.0 °C
2021-03-16 07:58:56.477 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_BinarySensor' changed from NULL to OFF
2021-03-16 07:58:56.574 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'farbigeLampenZoneHue_Farbtemperatur' changed from NULL to 61
2021-03-16 07:58:56.871 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KucheThermostat_Batterieladung' changed from NULL to 63.0
2021-03-16 07:58:57.045 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'farbigeLampenZoneHue_Farbe' changed from NULL to 0,0,0
2021-03-16 07:58:57.099 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'varAutomatisierungKuche' changed from NULL to OFF
2021-03-16 07:58:57.387 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad2Thermostat_TemperatureforHeatEco' changed from NULL to 19.5 °C
2021-03-16 07:58:57.490 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurBadRoomHue_Helligkeit' changed from NULL to 0
2021-03-16 07:58:57.626 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_TotalCleaningTime' changed from NULL to 555.0
2021-03-16 07:58:57.892 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TischRoomHue_Schalter' changed from NULL to OFF
2021-03-16 07:58:58.073 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'weisseLampenZoneHue_Helligkeit' changed from NULL to 0
2021-03-16 07:58:58.256 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurRoomHue_Helligkeit' changed from NULL to 0
2021-03-16 07:58:58.363 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurThermostat_Setpointheating' changed from NULL to 20.0 °C
2021-03-16 07:58:58.792 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KucheThermostat_Setpointheating' changed from NULL to 15.0 °C
2021-03-16 07:58:58.967 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Helligkeit' changed from NULL to 0.0
2021-03-16 07:58:59.050 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Hausturshellydw2483fda81f635192168034_Offnungswinkel' changed from NULL to -1.0 °
2021-03-16 07:58:59.233 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerRoomHue_Farbtemperatur' changed from NULL to 61
2021-03-16 07:58:59.497 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_DoNotDisturb' changed from NULL to OFF
2021-03-16 07:58:59.844 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_Batterieladung' changed from NULL to 100.0
2021-03-16 07:59:00.055 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_StateID' changed from NULL to 8.0
2021-03-16 07:59:00.359 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_Sensorseismicintensity' changed from NULL to 0.0
2021-03-16 07:59:00.580 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_TamperAlarm' changed from NULL to OFF
2021-03-16 07:59:00.755 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurThermostat_Sensortemperature' changed from NULL to 19.44 °C
2021-03-16 07:59:01.183 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Kontakt' changed from NULL to CLOSED
2021-03-16 07:59:01.209 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Helligkeit' changed from NULL to 211.0
2021-03-16 07:59:01.561 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurbadFibaroSensor_Alarmgeneral' changed from NULL to OFF
2021-03-16 07:59:01.879 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Huego1Hue_Farbe' changed from NULL to 0,0,0
2021-03-16 07:59:02.194 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachMorgen_ForecastHours24_Temperature' changed from NULL to 3.0 °C
2021-03-16 07:59:02.388 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurRoomHue_Farbtemperatur' changed from NULL to 61
2021-03-16 07:59:02.672 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TischRoomHue_Helligkeit' changed from NULL to 0
2021-03-16 07:59:02.983 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachAktuell_Aussentemperatur' changed from NULL to 4.63 °C
2021-03-16 07:59:03.199 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TischRoomHue_Farbe' changed from NULL to 0,0,0
2021-03-16 07:59:03.647 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_high' changed from NULL to 20.0 °C
2021-03-16 07:59:03.919 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_mode' changed from NULL to ON
2021-03-16 07:59:04.040 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachAktuell_GefuhlteTemperatur' changed from NULL to -0.15 °C
2021-03-16 07:59:04.247 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad2Thermostat_Temperaturemeasuredbythedevice' changed from NULL to 20.5 °C
2021-03-16 07:59:04.450 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_Signalstarke' changed from NULL to 4.0
2021-03-16 07:59:04.708 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 07:59:04.711 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 07:59:04.740 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 07:59:04.742 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become NULL
2021-03-16 07:59:04.875 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SteckdoseKuechenlicht_Electricmeteramps' changed from NULL to 0.0
2021-03-16 07:59:05.113 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_Offnungswinkel' changed from NULL to -1.0 °
2021-03-16 07:59:05.444 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' changed from NULL to 19.5 °C
2021-03-16 07:59:05.453 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 07:59:05.457 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 07:59:05.465 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 07:59:05.468 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 07:59:05.672 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 07:59:05.674 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FlurThermostat_Batterieladung' changed from NULL to 74.0
2021-03-16 07:59:05.675 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 07:59:05.683 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 07:59:05.687 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 07:59:05.929 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_NiedrigerBatteriestatus' changed from NULL to OFF
2021-03-16 07:59:06.070 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OpenWeatherMapGernsbachAktuell_Luftfeuchtigkeit' changed from NULL to 75.0
2021-03-16 07:59:06.252 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Arbeitszimmershellydw2483fda81fd99192168035_Vibration' changed from NULL to OFF
2021-03-16 07:59:06.559 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SchlafzimmerThermostat_Setpointheating' changed from NULL to 15.0 °C
2021-03-16 07:59:06.751 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BadezimmerThermostat_Batterieladung' changed from NULL to 66.0
2021-03-16 07:59:06.904 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_ControlFanLevel' changed from NULL to 102.0
2021-03-16 07:59:07.096 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_CleaningTime' changed from NULL to 49.0
2021-03-16 07:59:07.536 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SpotifyPlayerBridge_ActiveDeviceShuffle' changed from NULL to OFF
2021-03-16 07:59:07.798 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ArbeitszimmerThermostat_Sensortemperature' changed from NULL to 18.89 °C
2021-03-16 07:59:08.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Balkonturshellydw2483fda81f5a5192168033_Batterieladung' changed from NULL to 9500.0
2021-03-16 07:59:08.379 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bad2Thermostat_Thermostatmode' changed from NULL to 1.0
2021-03-16 07:59:08.758 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_low' changed from NULL to 10.0 °C
2021-03-16 07:59:08.924 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WohnzimmerThermostat_Batterieladung' changed from NULL to 65.0
2021-03-16 07:59:09.188 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Frederick_WaterBoxMode' changed from NULL to 201.0
2021-03-16 08:02:40.294 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'temperature_mode' received command OFF
2021-03-16 08:02:40.316 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_mode' changed from ON to OFF
2021-03-16 08:02:41.900 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 08:02:41.902 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:02:41.906 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_target' changed from 20.0 °C to 10.0 °C
2021-03-16 08:02:41.908 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:02:41.910 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:02:41.913 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:02:41.915 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 08:02:42.378 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 10.0
2021-03-16 08:02:42.387 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 08:02:42.479 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 10.0
2021-03-16 08:02:42.481 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 08:02:42.559 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 10.0
2021-03-16 08:02:42.564 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:02:42.640 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 10.0
2021-03-16 08:02:42.644 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:02:42.736 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 10.0
2021-03-16 08:02:42.739 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:02:42.753 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 10.0
2021-03-16 08:02:42.755 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:01.770 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'temperature_mode' received command ON
2021-03-16 08:03:01.842 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_mode' changed from OFF to ON
2021-03-16 08:03:02.197 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'temperature_target' changed from 10.0 °C to 20.0 °C
2021-03-16 08:03:02.954 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:02.956 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 08:03:03.020 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.025 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 08:03:03.036 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ArbeitszimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.038 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ArbeitszimmerThermostat_Setpointheating' predicted to become 19.5 °C
2021-03-16 08:03:03.127 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.137 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:03.174 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 10.0
2021-03-16 08:03:03.177 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:03.181 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.183 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:03.191 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'WohnzimmerThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.195 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'WohnzimmerThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:03.264 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.266 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'FlurThermostat_Setpointheating' received command 20.0
2021-03-16 08:03:03.272 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:03.275 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'FlurThermostat_Setpointheating' predicted to become 20.0 °C
2021-03-16 08:03:27.569 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'shelly:shellydw2:483fda81fd99' has been added.
2021-03-16 08:05:29.192 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'shelly:shellydw2:483fda81fd99' has been removed.
2021-03-16 08:06:21.094 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'shelly:shellydw2:483fda81f635' has been added.
2021-03-16 08:08:39.266 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'shelly:shellydw2:483fda81f635' has been removed.
openhab.log
2021-03-16 07:58:14.448 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2021-03-16 07:58:14.479 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '48.771204566436026,8.332357406616213'.
2021-03-16 07:58:14.484 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2021-03-16 07:58:23.808 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 192.168.0.3
2021-03-16 07:58:33.109 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-03-16 07:58:37.370 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2021-03-16 07:58:39.798 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-03-16 07:58:40.396 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.17.0.1/16, truncating to /24, some addresses might be lost
2021-03-16 07:58:51.116 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 1d1864a0-a894-4cdf-89a7-29e4e856a9fa, base URL = http://localhost:8080)
2021-03-16 07:59:12.753 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2021-03-16 08:00:47.436 [INFO ] [discovery.ShellyDiscoveryParticipant] - shellydw2-483fda81f635: Erkennung des Gerätes mit der IP-Adresse 192.168.0.34 ist fehlgeschlagen
2021-03-16 08:03:27.569 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shellydw2:483fda81fd99' to inbox.
2021-03-16 08:06:21.093 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shellydw2:483fda81f635' to inbox.
PS please ignore the shelly devices they are offline - openweather api and zwave shouldn’t and i need access to the zwave controller thing in order to reset my network
