Hello to anyone who can help. I have a Jasco Appliance Module ZW4102 that doesn’t seem to be able to be initialized in Openhab2. I see that Chris Jackson’s binding has a zwave device entry for the ZW4101. They look like the same device. Does the ZW4102 need to be added in to the binding for this to work? I can provide information on it if needed.
I guess your device has different device IDs so is slightly different than the database and therefore not identified. What does the UI show? Does t give a bunch of numbers relating to the device ID?
Is the 4101 exactly the same as the 4102? Maybe we need a separate database entry if not…
Take a look here for information on adding devices. Basically, register on the site, email me to get access, then upload the XML that OH generates for the device into the database and it should create most of the information.
If there’s config parameters, which I guess there probably are given the 4101 has them, you’ll need to add these and associations manually. Hopefully the instructions should be ok, but if not, give me a shout and I’ll try and help.
Hi Chris,
I emailed you regarding write access to the device database. I grabbed the node xml that was generated for this device and I’m ready to upload it.
Thanks for the help!
Michael
