Hi All,
I have several GE 28166-2 (ZW3104) (Identified by OpenHAB as GE 28167 ZW3104) dimmer outlet plugs that have always had an annoyance where instead of fading between dim levels, they jump immediately to whatever level you sent. They do fade correctly when sent the on/off commands, and the configurable parameters (dim rate/time) only apply when the switch is sent an On or Off command, they do not apply when the dimmer is sent a numeric value. Eventually I moved those dimmers somewhere less prominent in my house and promptly forgot why I disliked them. I needed some dimmers for holiday lights so I bought some Honeywell 39339 (ZW3107) dimmers, and immediately remembered why I hate Jasco dimmers. Instant level changes are incredibly ugly especially when you have scenes that involve a number of dimmers.
After significant research I was able to find a forum post that mentioned an undocumented parameter in Jasco’s newer (>2017) dimmers that feature the instant dim level change feature. Config parameter 6 toggles between instant level changes and smooth level changes.
This is the post that gave me the info I needed, it looks like this information may apply to a number of made by Jasco dimmers: http://forum.micasaverde.com/index.php/topic,50391.msg332062.html#msg332062
Dim Up/Down rate
Parameter Number: 6
Valid Values:
0 (Default): New Required Behavior (Instantly move to level)
1: Ramp up and down slowly (3.0d and previous versions behavior)
In order to test this I edited the XML files for my GE dimmers (28167_0_0.xml) and Honeywell Dimmers (39339_0_0.xml), I inserted the following lines between parameter 3 and 7 in those files:
<parameter name="config_6_1" type="integer" groupName="configuration" min="0" max="1">
<label>6: Undocumented Feature, Controls whether to fade to next light level or jump straight there</label>
<description>0= Instant Level Changes, 1= Smooth Level Changes</description>
<default>0</default>
</parameter>
I can confirm this works properly on both model dimmers I have. I suspect this may work on a number of Made-by-Jasco devices, I can find other people complaining about this behavior both here as well as other forums (SmartThings, Hubitat, Reddit etc) but this is the first time I’ve come across a resolution.
I can add this to the database (I’ll improve the verbiage a bit first) once my access is approved again and I review the process for making changes on the new site, but I wanted to open a topic here rather than just quietly editing the two devices I own because I have spent so much time trying to figure this out and I know there are others that have this same issue with other model Jasco/GE/Honeywell dimmers.
