Hi super new here, so apologies if I have missed something obvious…
Setup:
Raspberry Pi v2.
OpenHab 2.4
ZWave Gateway Aeotec Z-Stick Gen 5
Jasco ZW6302 (GE) Smart Motion Sensor
and a couple of other things that are currently working with no issues.
So here’s my issue, using my Gen 5 and place it into ADD mode. I then press the button on the back of my Smart Sensor and the Gen 5 blinks quickly showing the new Thing has been added.
So far this is good.
I then place my Gen 5 back into my Pi, go into Paper UI, under Things press “+”, and then select Z-Wave bindings… It does its magic and I get a generic “Z-Wave Node” stating Unknown Device…
This is all that I see in the logs…
[WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! Manufacturer data not known.
[INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:f16c2086:node6’ to inbox.
If i’m reading this correctly, this version of the GE Smart Motion Sensor is not in the Things DB?
How do i update or define this Sensor in the Things lookup and what info do I need?
Cheers.
