Hi @All,
i fund the following issue when use the UPNP Binding
java.lang.IllegalArgumentException: Illegal character in path at index 105: https://e-cdns-images.dzcdn.net/images/cover/46c6c6215af2eb0bc24f667efeaab622/1000x1000-000000-80-0-0.jpg
Caused by: java.net.URISyntaxException: Illegal character in path at index 105: https://e-cdns-images.dzcdn.net/images/cover/46c6c6215af2eb0bc24f667efeaab622/1000x1000-000000-80-0-0.jpg
This appears when the Binding grap the Image-Path for the Album from Renderer.
Is it possible to fix this by self or must there be change to code of binding ?
And as the Binding run for some time it loose connection to the renderer and this can only be fix with scan for new UPNP devices (ADD THING).
Regards Mario
