I have installed OpenHABian on Pine64 with Tellstick Duo attached.
Since there is no ARM64 version of Telldus-core in Debian, I compiled v. 2.1.2 from sources.
I verified that tdtool -l
lists my devices (specified in /etc/tellstick.conf
) and sensors.
Then I added the telldus-core bridge to OpenHAB in the paperUI, with path set to /usr/lib
, since this is the location of libtelldus-core.so
Here is the relevant part of events.log
2017-10-21 19:43:44.302 [ThingAddedEvent ] - Thing 'tellstick:telldus-core:f01a27db' has been added.
2017-10-21 19:43:44.316 [hingStatusInfoChangedEvent] - 'tellstick:telldus-core:f01a27db' changed from UNINITIALIZED to INITIALIZING
2017-10-21 19:43:44.322 [hingStatusInfoChangedEvent] - 'tellstick:telldus-core:f01a27db' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Could not initialize class org.tellstick.JNA$CLibrary
and in openhab.log:
2017-10-21 19:43:44.314 [INFO ] [andler.core.TelldusCoreBridgeHandler] - Loading telldus-core from /usr/lib
2017-10-21 19:43:44.318 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'tel
java.util.concurrent.ExecutionException: java.lang.NoClassDefFoundError: Could not initialize class org.tellstick.JNA$CLibrary
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_121]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_121]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:194)
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:83)
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:67)
at org.eclipse.smarthome.core.thing.internal.ThingManager.doInitializeHandler(ThingManager.java:738)[105:org.eclipse.smartho
at org.eclipse.smarthome.core.thing.internal.ThingManager.initializeHandler(ThingManager.java:664)[105:org.eclipse.smarthome
at org.eclipse.smarthome.core.thing.internal.ThingManager.access$12(ThingManager.java:639)[105:org.eclipse.smarthome.core.th
at org.eclipse.smarthome.core.thing.internal.ThingManager$2.apply(ThingManager.java:681)
at org.eclipse.smarthome.core.thing.internal.ThingManager$2.apply(ThingManager.java:1)
at org.eclipse.smarthome.config.core.BundleProcessorVetoManager.applyActionFor(BundleProcessorVetoManager.java:124)[94:org.e
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:1016)[105:org.eclip
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:464)[105:org.eclipse.smarthome.core.t
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:212)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:131)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1)
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:126)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:51)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:70)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:74)
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:60)
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:187)
at org.eclipse.smarthome.io.rest.core.thing.ThingResource.create(ThingResource.java:204)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_121]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_121]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_121]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandle
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatche
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatch
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourc
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispat
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)[158:org.glassfish.jersey.c
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)[158:org.glassfish.jersey.co
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)[158:org.glassfish.jersey.co
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)[158:org.glassfish.jersey.core.jersey-server:2.22.
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)[157:org.glassfish.jersey.core.jersey
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)[158:org.glassfish.jersey.core.jersey-server:2.2
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154)[158:org.glassfish.jersey.core.jersey-
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473)[155:org.glassfish.jersey.containers.jersey-c
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)[155:org.glassfish.jersey.containers.jersey-conta
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)[155:org.glassfish.jersey.containers.jers
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)[155:org.glassfish.jersey.containers.jers
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)[155:org.glassfish.jersey.containers.jers
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)[9:com.eclipseso
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[172:org.op
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[80:org.eclipse.jetty.server:9.2.19.v2016090
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[79:org.eclipse.jetty.security:9.2.19.v2016090
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[80:org.eclipse.jetty.server:9.2.19.v201
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[80:org.eclipse.jetty.server:9.2.19.v20
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[172:org.ops4j.pax.web.p
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[80:org.eclipse.jetty.server:9.2.19.v2016
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[80:org.eclipse.jetty.server:9.2.19.v201
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[80:org.eclipse.jetty.server:9.2.19.v2016090
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[172:or
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v201609
at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[71:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v201609
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v2016090
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.tellstick.JNA$CLibrary
at org.openhab.binding.tellstick.handler.core.TelldusCoreBridgeHandler.init(TelldusCoreBridgeHandler.java:99)
at org.openhab.binding.tellstick.handler.core.TelldusCoreBridgeHandler.initialize(TelldusCoreBridgeHandler.java:109)
at org.eclipse.smarthome.core.thing.internal.ThingManager$9.call(ThingManager.java:741)
at org.eclipse.smarthome.core.thing.internal.ThingManager$9.call(ThingManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:181)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
... 1 more
Any idea what is the problem?
And did someone manage to make Tellstick binding work on Pine64?
