Minor issue really, probably due to the nature of the old rules-dsl engine…
Just wondering is there any way to avoid it, as usually I keep my openhab.log clean, no logging there for days, filtered out all irelevant info messages, configured email alerts when error pops up, so its just ugly to get hundred lines exception every time I edit a rule.
I assume the error originates from the fact that I have some timers that get “interrupted” by reloading the file.
Example, after item is triggered, start timer 10 minutes and then do something. so if rule is edited 5min after the timer has started, it messes him up (I guess).
I think the phenomena is not happening if I edit some other rule file where there is no timers, and no rules running at that moment.
Can this be prevented? Can I manually issue a command to stop the running rule before editing? Of course, this error is benign as it never happens again, until the next editing.
Another workaround would be to separate all rules with timers in their own file.
2024-12-19 13:08:36.367 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'scenes.rules'
2024-12-19 13:18:15.650 [WARN ] [ore.internal.scheduler.SchedulerImpl] - Scheduled job '<unknown>' failed and stopped
java.lang.reflect.UndeclaredThrowableException: null
at jdk.proxy112.$Proxy234.apply(Unknown Source) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:189) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:88) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
Caused by: org.openhab.core.model.script.engine.ScriptExecutionException: The name '<unkown>' cannot be resolved to an item or type; line 0, column 0
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1222) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1152) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:878) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:47) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:30) ~[?:?]
... 9 more
2024-12-21 13:29:16.547 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'multimedia.rules'
2024-12-25 00:31:26.549 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'scenes.rules'
2024-12-25 00:39:53.907 [WARN ] [ore.internal.scheduler.SchedulerImpl] - Scheduled job '<unknown>' failed and stopped
... 9 more
