java.lang.ClassNotFoundException with sendLogNotification
I have just installed openhab 2.5.0 with openhabian. I have connected to the openhabcloud enabling the addon. I’m alson using Rule Engine for rule creation.
Now I’m trying to create a silly demo rule that just record a log whenever I run it. This is the rule’s code (ECMAScript):
var NotificationAction = org.openhab.io.openhabcloud.NotificationAction;
NotificationAction.sendLogNotification("This is a log notification");
The problem I have is that whenever I run this rule I get the error:
2019-12-23 16:30:32.835 [WARN ] [e.automation.internal.RuleEngineImpl] - Fail to execute action: 1
java.lang.RuntimeException: java.lang.ClassNotFoundException: org.openhab.io.openhabcloud.NotificationAction.sendLogNotification
	at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:397) ~[nashorn.jar:?]
	at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:449) ~[nashorn.jar:?]
	at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:406) ~[nashorn.jar:?]
	at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:402) ~[nashorn.jar:?]
	at jdk.nashorn.api.scripting.NashornScriptEngine.eval(NashornScriptEngine.java:155) ~[nashorn.jar:?]
	at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[?:1.8.0_222]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
	at java.util.Optional.ifPresent(Optional.java:159) ~[?:1.8.0_222]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) ~[?:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1189) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1037) [bundleFile:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1053) [bundleFile:?]
	at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:288) [bundleFile:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [bundleFile:?]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: java.lang.ClassNotFoundException: org.openhab.io.openhabcloud.NotificationAction.sendLogNotification
	at jdk.nashorn.internal.runtime.NativeJavaPackage.classNotFound(NativeJavaPackage.java:162) ~[nashorn.jar:?]
	at jdk.nashorn.internal.scripts.Script$2$\^eval\_.:program(<eval>:3) ~[?:?]
	at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:637) ~[nashorn.jar:?]
	at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:494) ~[nashorn.jar:?]
	at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:393) ~[nashorn.jar:?]
	... 72 more
Any help?
A similar rule, but statically created at /etc/openhab2/rules/test.rule is working. The working rule is:
    import org.openhab.io.openhabcloud.NotificationAction.*
    rule "TestRule"
    	System started
    	sendLogNotification('TEST RULE: Hola mundo')
Actions are registered as OSGi services, so you won’t be able to access them by importing the class. You may want to consider taking a look into the helper libraries…
Specifically, openhab-helper-libraries/Core/automation/lib/javascript/core/actions.js at master · openhab-scripters/openhab-helper-libraries · GitHub
Just be aware that the Jython/Python libraries are MUCH more advanced than the ones for JavaScript.
BTW, you used quotes in your post rather than code fences. Try triple ticks (```) on the lines before and after.
Thank you Scott. Now I have it working. The problem was that I had no completely installed helped libraries
