I sent debug files in a message.
Look like you ran into both problems I mentioned here: Java on non-openHABian
Both are known and workarounds are available. You can use the search on how to install @5iver PR for jython. And Iām quite sure there is also a thread about updating nrjavaserial. Report back if there are further problems.
It does not work for me.
Now I try to use what was working before trying Java11.
I reverted back everything. Despite of it when I start second time rule enige with org.openhab.core.automation.module.script.rulesupport-2.5.0-SNAPSHOT.jar in addon folder Rule engine gives the following error in the attached file.
ruleengine.log (139.1 KB)
After that I stop OH, delete this file from addon folder. Empty Catch and TMP folders in Userdata.
Than I restart OH twice and activaty my yard.py rules and it loads succefully.
Here is the second log: ruleengine2.log (14.6 KB)
If all you did was remove the jar for the Jython addon and Jython started, then you had Jython configured in your EXTRA_JAVA_OPTS. You canāt have Jython manually installed AND use the Jython addon. I suspect this is the cause of the exceptions.
I do not understand what you mean. C:\openhab2\userdata\tmp and C:\openhab2\userdata\cache folders are containing working information of Openhab. If I empty them Openhab recreate everything from the beginning based on actual set up including Jython I guess. In many cases if I update a binding I have to do that otherwise binding information wonāt be refreshed.
If you remove the Jython addon from the /addons/ directory and clear the cache, Jython will not be installed unless you have it also manually installed. Remove any reference from EXTRA_JAVA_OPTS and it should not reappear.
Basically, if you have the Jython addon installed, remove the Jython references from EXTRA_JAVA_OPTS, except possibly python.path, if you need to add other directories for libraries. What do you have in your EXTRA_JAVA_OPTS?
A fellow man of taste and distinction, I see.
Absolutely false. Here is the repo:
# Zulu Java (for OpenHAB)
deb http://repos.azulsystems.com/debian stable main
# OpenHAB (Stable) Debian Repo
deb https://dl.bintray.com/openhab/apt-repo2 stable main
I included the OpenHAB repository, too. But this is all right there in Installation Docs.
I am on OpenHAB v2.5.5-1 (stable) on Armbian stable, and followed the recommendation to use Zulu 8 and it has been flawless on my ODRIOD-XU4. But I am conservative by nature. If you are more adventurous, you could perhaps help the project by testing newer versions of Java.
You did not mention what hardware you are running on, I have an idea because Armbian, however all these people talking about 64-bit but you did not specify that (or I missed it). But for armhf
for instance you will want the zulu-embedded-8
package (I found there was no āregularā zulu-8
package for armhf
(Perhaps I should ad that last little tid-bit to the docs.)
Ok. I need to clean these settings. I made several trials and that is the reason. Now Java11 works. Iām working on run OH as a service now under win10 as it does start with start.bat only for some reason. Here is my EXTRA_JAVA_OPTS: -Xbootclasspath/a:C:\openhab2\conf\automation\jython\jython-standalone-2.7.0.jar -Dpython.home=C:\openhab2\conf\automation\jython -Dpython.path=C:\openhab2\conf\automation\lib\python
I donwloaded latest jython-standalone-2.7.2.jar and replaced 2.7.0 but I updated extra java opts, and now 2.7.0 again, that could be one reason?
Iām using armbian as well, I donāt see Java 11:
$ apt-cache search zulu
libreoffice-l10n-zu - office productivity suite -- Zulu language package
hyphen-zu - Zulu hyphenation patterns
libzulucrypt-dev - development files for libzulucrypt-1.2.0
libzulucrypt-exe-dev - development files for the libzulucrypt-exe
libzulucrypt-exe1.2.0 - provide the main functions of zulucrypt
libzulucrypt-plugins - collection of plugins for zulucrypt
libzulucrypt1.2.0 - provide the functions of zulumount
libzulucryptpluginmanager-dev - development files for libzulucryptpluginmanager
libzulucryptpluginmanager1.0.0 - provides support for plugins
zulucrypt-cli - tool for encrypting volumes
zulucrypt-gui - graphical front end for zulucrypt-cli
zulumount-cli - tool that manages encrypted volumes
zulumount-gui - graphical front end for zulumount-cli
zulupolkit - handler the polkit privileges
zulusafe-cli - cli that manages encrypted volumes
zulu-embedded-8 - Azul Systems Zulu Embedded is a binary distribution of OpenJDK
And ever checked whatās in there ?
They abandoned that long ago, somewhere around Java 8u156 if I recall correctly.
So unless they changed anything very recently, my original statement remains true.
Itās why we had to completely rework the openHABian Java install routine to use Azul API now.
Hell, itās even why we started looking for alternatives and have Adopt now.
Correct, the repo only contains the amd64 binaries and they are up to date but what @mstormi said is very true. I can promise that it uses the API except on amd64 and then it will even fall back to the API if the machine doesnāt meet the requirements.
Look at the code before making assumptions. I wrote the code, it wonāt use that repo on ARM.
I managed to run now Java 11 with openHAB 2.5.6 Build #139.
Windows10
openjdk version ā11.0.2ā 2019-01-15
OpenJDK Runtime Environment 18.9 (build 11.0.2+9)
OpenJDK 64-Bit Server VM 18.9 (build 11.0.2+9, mixed mode)
I deleted " -Xbootclasspath/a:C:\openhab2\conf\automation\jython\jython-standalone-2.7.2.jar" from EXTRA JAVA OPTS and copied it to
C:\openhab2\runtime\lib\boot\jython-standalone-2.7.2.jar
Now it works and load Python and Java rules.
When I restart Openhab it still not loads rules in C:\openhab2\conf\automation\jsr223
It runs only if I save it again.
If I copy this file to addon folder: org.openhab.core.automation.module.script.rulesupport-2.5.0-SNAPSHOT.jar then I get the following errors and rules are not starting.
ruleengine_debug.log (46.9 KB)
I have found this in wrapper.log
STATUS | wrapper | 2020/06/11 06:11:01 | Launching a JVM...
INFO | jvm 5 | 2020/06/11 06:11:01 | WARNING: package org.apache.karaf.specs.locator not in java.base
INFO | jvm 5 | 2020/06/11 06:11:02 | Error: Could not find or load main class org.apache.karaf.wrapper.internal.service.Main
INFO | jvm 5 | 2020/06/11 06:11:02 | Caused by: java.lang.NoClassDefFoundError: org/apache/karaf/main/ShutdownCallback
ERROR | wrapper | 2020/06/11 06:11:02 | JVM exited while loading the application.
FATAL | wrapper | 2020/06/11 06:11:02 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2020/06/11 06:11:02 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2020/06/11 06:11:03 | <-- Wrapper Stopped
Title of thread is āJava on non-openHABianā not āJava 11 on ā¦ā so I still donāt understand why everyone keeps talking about Java 11?
Installation docs recommend (Zulu) Java 8 anyway. Thatās what I have been on and so far, so good.
I just installed zulu-embedded-8
a few weeks ago on armhf
architecture (ODROID-XU4) using apt
and the repo I mentioned above. Now, if something changed in more recent versions, I donāt know. But on Azul Java 8 you can definitely install via apt
repo:
trs80@odroidxu4:~$ dpkg-query -l *zulu*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un zulu-8 <none> <none> (no description available)
ii zulu-embedded-8 8.25.0.76 armhf Azul Systems Zulu Embedded is a binary distribution of OpenJDK
This thread was spun off another thread about trying Java 11 on openHABian.
This version is about 2.5 years old.
They are availabe but they are super old versions the current version 1.8.0_252
your repo installed 8.25.0.76
⦠as I / we already told you here:
Suddenly it all makes sense now! lol
I donāt know a lot about Java, but I sort of had the impression that this old version (8) was some sort of ālong term stableā type thing, sort of like Linux 2.6 or 3.(I forget now) or something? Is that a wrong/bad assumption?
Well, my assertion was āAzul Zulu is apt basedā I never said anything about any particular version.
Now, understanding that this was spun off a thread about Java 11, everything becomes clear.
So anyway, sounds like sooner or later I wonāt be able to use it. It has been fine so far, but I suppose Iām glad I stumbled into this thread.
Since you guys seem to be quite knowledgeable about the Java stuff, if Azul want to be special snowflakes, instead of keeping it apt based on newer versions, why stick with them at all? Why not just switch then to something like openjdk which is already available (the default in fact, if I am not mistaken) in Debian?
Performance, historically Azul has provided great performance especially on ARM platforms. openJDK does not have the best performance especially with ARM.
Licensing. While OK at first sight, thatās an ever-annoying issue when your opponent supplier is Oracle.
Wow, I had no idea that OpenJDK actually came from Oracle, until I looked it up just now⦠What a mess.
I never thought twice about it, because itās in Debianā¦
Opponent is exactly right, Oracle needs to take their dinosaur business models and go DIAF.
Thanks for the information, guys.
