Java SE6 for installation SmartHome-Designer on iMac OS X?
I tried an installation of released and snapshot version but always get the message “Um SmartHome-Designer öffnen zu können, muss die alte Java SE 6-Runtime-Version installiert werden.” Translation could be “To open SmartHome-Designer you have to install the old Java SE6 Runtime version”. If I have a look to the prerequisites I found:
  • a JVM compliant with 1.7 or above
    In another Topic here today the answer was to install a SDK instead of the JRE.
How can I install without this really old Java SE 6? And afterwards to run the SmartHome-Designer on my MacBook Air Sierra is there an SDK really necessary?
Kind regards
Steffen
This is a common issue on Mac, with the old 1.6 being the default JVM. Please search the Internet for solutions, like this one.
hi Steffen
did you find a simple solution? I’ve the same problem (running macOS sierra). The link bellow from watou is for me not helpful to solve it in reasonable time …
BR Simno
You have to install Oracle Java JDK (not only JRE). Then it’s not necessary anymore to install the old Apple Java.
perfect. this did the trick for me. vielen dank!
