jnt2007
(Anton)
June 14, 2018, 7:25am
1
Platform information:
OS: Ubuntu
openHAB version: 2.3.0
Hi. I have a rule for getting status of my HA device.
I need to send register request first, and then request for getting info.
Working ok, but sometimes I get java.util.concurrent.ExecutionException with unknown reason. Also I can’t catch this exception usng try-catch.
Anybody can help me to find whats wrong with this rule?
2018-06-14 09:58:50.277 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: org.eclipse.jetty.io.EofException
2018-06-14 09:58:51.102 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@af0fba(l:/192.168.1.169:49594 <-> r:/192.168.1.116:8181,closed=false)[HttpChannelOverHTTP@16863eb(exchange=HttpExchange@1b981d4 req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@19f060(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@f7ea06{s=START}],recv=HttpReceiverOverHTTP@dab648(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]]
And my rule…
rule "Get panel state"
Time cron '0 0/1 * 1/1 * ? *'
try {
var reg_url = "http://192.168.1.116:8181/remote/json-rpc"
var contenttype = "application/json"
var POSTrequest = '{"params": ["192.168.1.169", 1818, "user"],"jsonrpc": "2.0","method":"PmaxService/registerClient", "id":11}'
sendHttpPostRequest(reg_url, contenttype, POSTrequest)
var url = "http://192.168.1.116:8181/remote/json-rpc"
POSTrequest = '{"params": [ 1 ],"jsonrpc":"2.0","method":"PmaxService/getPanelState", "id":11}'
var output = sendHttpPostRequest(url, contenttype, POSTrequest)
val String status = transform("JSONPATH", "$.result.state", output)
logInfo("received_status", status)
if(status == 'DISARM') {
postUpdate(System_ARMED_API, status)
else if (status == 'HOME'){
else if (status == 'AWAY'){
else {
return
} catch(Exception e) {
logError("received_status", "exception" + e.getMessage)
vzorglub
(Vincent Regaud)
June 14, 2018, 8:08am
2
try {
logInfo("RULE",output)
// var url = "http://192.168.1.116:8181/remote/json-rpc"
// contenttype = "application/json"
else {
return
jnt2007
(Anton)
June 14, 2018, 8:32am
3
You sent only first request, which does not return status data. In this case transformation fails
Again - need to send 2 requests one by one: register and get data
rlkoshak
(Rich Koshak)
June 14, 2018, 1:38pm
4
An EOF exception is almost always caused by the remote end closing the connection before all of the expected data has been received. Are there any logs or other information available on the remote end that might show you a little more info?
What happens if you put in a Thread::sleep between the two requests so the remote end gets a little time between requests? I wouldn’t expect it to need more than 500 msec if this works most of the time.
You probably can’t catch this exception because it looks like it is caught in the HTTP Action itself.
jnt2007
(Anton)
June 15, 2018, 5:24am
5
Thank you for your really helpful answer. Just adding sleep 500 ms improoved more stability. Now I’m testing with 1000 ms.
Also, thank you for pointing out the root of the problem. Need to investigate how to get logs from another side and check it.
pacive
(Anders Alfredsson)
June 15, 2018, 6:03am
6
I’m not sure about this, but if you save the response from the first POST to a variable the rule would have to wait for the operation to finish before moving on to the next step.
var dummy = sendHttpPostRequest(reg_url, contenttype, POSTrequest)
You will get a warning in the logs that the variable is never used, but it’s safe to ignore. You can always log the variable in a logInfo statement to get rid of the warning and improve debugging of the rule.
billfor
(Bill)
March 14, 2020, 9:39pm
7
If you don’t mind silencing all http request errors you could add this to the org.ops4j.pax.logging.cfg:
log4j2.logger.http.name = org.eclipse.smarthome.model.script.actions.HTTP
log4j2.logger.http.level = OFF
