Hi guys,
I have switched from:
openjdk version “11.0.10” 2021-01-19 LTS
OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
OpenJDK Client VM Zulu11.45+27-CA (build 11.0.10+9-LTS, mixed mode)
to:
openjdk version “11.0.14” 2022-01-18
OpenJDK Runtime Environment (build 11.0.14+9-post-Raspbian-1deb11u1)
OpenJDK Server VM (build 11.0.14+9-post-Raspbian-1deb11u1, mixed mode)
I have done this using opion 45 in openhabian-config according to:
Major Java provider switch ## December 15, 2021
We have switched to supporting only the OpenJDK package provided by default from
the APT repo for all new installations of openHABian. Existing installations
will be unaffected, however you will no longer receive updates to your current
Java install until you install Java from the new provider which you can do by
running menu option 45.
My system info:
Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.15.30-v7l+
Platform = Raspberry Pi 4 Model B Rev 1.1
openHAB 3.3.0.M2 - Milestone Build
After Java version change I can see, during the stratup, something like this:
2022-03-31 08:51:02.001 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://internal.id.core.openhab.org/}UUIDResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:67) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:279) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:829) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:550) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:915) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:987) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:285) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpOutput.close(HttpOutput.java:638) ~[bundleFile:9.4.43.v20210629]
at org.apache.cxf.transport.http.AbstractHTTPDestination$WrappedOutputStream.close(AbstractHTTPDestination.java:791) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.AbstractConduit.close(AbstractConduit.java:56) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination$BackChannelConduit.close(AbstractHTTPDestination.java:722) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:63) ~[bundleFile:3.4.5]
... 43 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:182) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:130) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:493) ~[?:?]
at java.nio.channels.SocketChannel.write(SocketChannel.java:507) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:273) ~[bundleFile:9.4.43.v20210629]
... 43 more
When searching through topics I have found something similar
but in my case it is probably not related to any binding because everything looks fine (at first and second sight
Is it something I should be worry about?
Thanks for any information.
