I’m using a rule to capture an update on my energy, I’m just checking if item('energy;).changed() will fire for all events ie if I see to values the same will it fire? or is receivedUpdate()
correct?
What is the correct syntax for capturing all values?
see below example.
rules.when().item("Energy_Mains_Total_minute").changed().then(event => {
console.log("Energy JS wattmin: " + event.newState)
}).build("Energy Consumption", "calculate energy usage every update");
