Platform information:
- Hardware: quad core Intel Celeron J4105 (-MCP-), x86_64, 8 GB RAM, 150 GB Storage
- OS: Linux 5.15.0-73 via Ubuntu 22.04.2 LTS
- Java Runtime Environment: openjdk 18.0.2-ea (edit: same with openjdk 17)
- openHAB version: 3.4.4, JavaScript Binding is installed
Issue of the topic:
Creating js files in $OPENHAB_CONF/automation/js
with JSRules doesn’t create a rule/script (nothing visible in the web interface), crons aren’t executed and no log output is produced. The files and folders are owned by the openhab
user.
This worked some time ago via the docker image. In this current setup I’m using the ubuntu/debian installation of openhab.
- Rules code related to the issue:
rules.JSRule({
description: "Just a test",
triggers: [triggers.GenericCronTrigger("* * * * *")],
execute: (event) => {
console.log('Hello');
tags: [],
Any help appreciated.
