rtvb
(Robert)
1
Should it be possible to use a javascript in the label of an item definition?
I am trying something like:
Number Node7_Power "Consumption [JS(milli.js):%.3f kW]"
The actual value returned is in Watts, but I like to show (not convert) it as kilowatts.
If I use the above, basic UI show “NaN” as the value.
rossko57
(Rossko57)
2
That would force a requirement for all possible UI to support javascript?
rtvb
(Robert)
3
map and scale transform are supported. Those are handled server side?
rtvb
(Robert)
5
Relevant in the sense that this isn’t a working solution either.
