JavaScript rule: ...padStart() is not a function in <eval>
  • openHAB version: 3.2
I’m struggling with JS standard, built-in String.prototype.padStart() method.
I’m using the scripting scratchpad to run this code:
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.rule." + ctx.ruleUID);
var x = 18;
logger.info(x.toString());
logger.info(x.toString().padStart(3,'0'));
So I’m currently using this: :sweat_smile:
logger.info(("000" + x.toString()).substr(-3,3));
Anyone with a working code maybe? That would be great, thanks.
padStart is part of ECMA 2017 while bare OH uses ECMA 5.1.
See https://stackoverflow.com/questions/2686855/is-there-a-javascript-function-that-can-pad-a-string-to-get-to-a-determined-leng for ‘selfmade’ functions.
Just one additional bit of info. If you want to use a more recent version of ECMAScript, install the JS Scripting add-on which offers ECMAScript 11.
Thanks guys!
