Javascript string.split() fails with special character
Hi all,
any idea why this fails if I put it inside a rule?
take a look at the special character (round open bracket)
var String callerNameStripped = callerName.split("(").get(0)
Error: Unclosed group near index 1
while this works?
var posSplit = callerName.indexOf("(")
Stefan
Hi Stefan,
it should not fail because of the bracket. I think it fails because of “var String callerNameStripped”.
try only this (without string):
var callerNameStripped = callerName.split("(").get(0)
It thinks the ( is part of a regex. Escape the ( with a \ or maybe \\.
Thanks for offering help. Unfortunately both doesn’t lead to success.
If a remove the “String” word, nothing changes.
Btw: I think the error message is clear “unclosed group”, so it’s expecting another round closing bracket :-/
It I try to escape the error turns into:
Invalid escape sequence (valid ones are \b \t \n \f \r \" \' \\ )
Btw: I tried already to create a string variable to save the seperator, like var seperator=“(”, but then the “unclosed group” error still occurs. Then I tried to use regex (although I have no clue if I am doing it right), still no success.
Maybe a bug?
Stefan
Did you try “\\(”
That’s it!!! Thanks mate
