JavaScript - Transformation Services missing in openhab 4
Hi there,
I’m missing the JavaScript - Transformation Services in openhab 4.
https://www.openhab.org/addons/transformations/javascript/
How can I now make sure that my items which are linked to a float channel only hold integer values so they only trigger a change when a massive change happend and not somthing minimal.
So 45.67 to 45.66 shouldn’t trigger thats why I saved it to 45 in my item.
I used the following javascript transform script before:
(function (i) {
    return parseInt(i) // The value sent by OH is a string so we parse into an integer
})(input)
I hope the function return till openhab 4 gets released. Or is there a other way to do this now?
Since Milestone 2 you just need to install the JavaScript Scripting add-on.
Hi @J-N-K,
so happy to here that. Thanks so much!
@J-N-K: How is the new syntax to use the transformation in an item channel? The following is not working:
{channel="deconz:humiditysensor:bridge:00158d0004210ddb010405:humidity"[profile="SCRIPT", function="float2int.script"]}
The profile name is JS. If that doesn’t help, I can’t support you, except my general advice not to use textual configuration.
The profile name ´JS´ does not work. It gives the following error in the log:
blubb.items :
{channel="deconz:humiditysensor:bridge:00158d00042fdca5010405:humidity"[profile="JS", function="float2int.script"]}
log :
[WARN ] [.thing.internal.CommunicationManager] - No ProfileFactory found which supports profile 'system:JS' for link 'MS_Werkstatt_Luftfeuchte -> deconz:humiditysensor:bridge:00158d00042fdca5010405:humidity'
Side-Topic:
With the update to openhab 3 I changed my complete textual configuration because of many advices from very popular community members. One year later now I’m changing everything back except the Things to textual configuration.
It just works so much quicker and easier for me.
I can rename via search-and-replace quickly and having a new sensor is most of the time copy and paste of one existing sensor plus two search-and-replace calls for the itemname and the channelid.
I’m so happy textual configuration is still possible.
And - as you can see - struggle to find out how to configure things that you can configure with one click in the UI.
Do you use M2? Before M2 it’s SCRIPT and you have to prefix the filename with js. With M2 it’s JS and you only need to use the filename.
Please check out the documentation
It is not fully compatible.
Instead of function, it’s now called toItemScript and toHandlerScript
Okay I recognized know that my problem is not to call the transform function in the profile.
The problem is that the function is not working if I use the simple function Math.round().
{channel="deconz:humiditysensor:bridge:00158d00042fdca5010405:humidity"[profile="transform:JS", toItemScript="float2int.js"] }
This gives absolut no value and no error in the log:
(function (data) {
    return Math.round(data)
})(input)
This example gives me always 11:
(function (data) {
    return 11
})(input)
So why can’t I use the Math.round function? And why don’t I get an error?
Is there maybe a bug im 4.0.0.M2?
I’m happy for any suggestions!
You can’t round a String. input/data is a String.
Thats why among many options also tried
(function (data) {
    return Math.round(Number(data))
})(input)
But this also didn’t work.
EDIT: Oh I see you’ve fixed the profile=“JS”.
try
(function (data) {
    return data
})(input)
Like in the documentation you posted profile=“transform:JS” is working. But the Math.round actually not.
The documentation here is not working:
My problem is still to make an interger from the float value which is not working yet.
I don’t know much about javascript. If you want to try jrubyscripting:
  • install jrubyscripting addon
profile="transform:RB", toItemScript="|input.to_f.round"
Add some logging (you can do that easily now in OH 4 because the JS Scripting helper library is available) and log out the intermediate steps. You can use console.log() in a transform.
If your Item has units (e.g. 12.34 W as opposed to 12.34) Number(data) won’t work. That will return NaN. But parseFloat is a little more flexible in that it will parse up to the first non-numeric character so will ignore the units.
console.log(Math.round(Number("12.45 W")));
console.log(Math.round(parseFloat("12.45 W")));
produces
NaN
12
@rlkoshak as very often you are my hero! Thank you so much not only for the solution but especially for the explanation. I learned already so much from your posts here in the forum.
Without people like you we wouldn’t be able to have a smarthome Thanks a lot.
data: 69.54 %
parseFloat(data): 69.54
Number(data): NaN
I know the topic is solved, just wanted to add this helped me to fix the NaN when adding units and using a JS transform, as stated it is a string that is received in variabele i where the first is the value and the second argument the unit.
When returning you also need to return the unit.
I solved it like this, hope it helps somebody.
Tom
.items
Number:Energy           ow_count_1D_D74C0F000000_B   "ow_count_1D_D74C0F000000 Rest [JS(electeller-achterbouw.js):%.0f kWh]"                             <energy>                 (GROUND_FLOOR_CORRIDOR, Electricity)                { channel="onewire:basic:mybridge:ow_count_1D_D74C0F000000:counter1" }
electeller-achterbouw.js file
// Electriciteits teller - achterbouw
(function (i) {
    inValue = i.split(" ")[0];
    inUnit = (i.split(" ").length == 2)?i.split(" ")[1]:"";
    // op 1/1/2018 0:0:0 is de teller 36785360
    inValue = inValue - 36785360;
    return (inValue / (2000)).toFixed(3) + " " + inUnit;
})(input)
If you are using JS Scripting instead of Nashorn JS this is overly complex.
(function (i) {
  let parsed = Quantity(i);
  let inValue = parsed.int - 36785360;
  return (inValue / 2000).toFixed(3) + " parsed.unit;
})(input)
Of course, it would be even better to stay working with Quantity but I have no idea what units is being used here so I have no idea what unit to set on 36785360. It’s unclear how doing these operations actually result in a value in the same unit in the end anyway unless the binding is reporting the wrong unit to begin with. So returning the same unit as was passed in is almost certainly wrong.
If this transform is doing a conversion of units, all you probably need to do is set the unit metadata on the Item to the unit you want and you can use the rounding Basic Profile to round the value before the Item gets updated.
The problem with reopening a two year old thread, is it’s missing two years worth of development in the original.
Hi Rich,
Thank you for your answer.
I am currently doing a migration of my openhab 1.0 (yes) and openhab 2.5 instances to the openhab 4.
The value is from a onewire counter that is connected to an electricity pulse counter that gives 2 pulses / watt.
My goal is to configure as much as possible in text files as i prefer that more.
I wrote the first openweb net connector 10 years ago or so :slight_smile:
It is a learning curve to configure what was build in years (all my rules).
I will adapt the scripts, i didnt know it could be casted.
All thanks for the great work!
Greetings
Tom
