As you found, the answer is there ya nothing built in to tell you which triggered the rule. You can tell the difference between different types of triggers by checking to see if event is defined as be what members of event are defined, but that won’t help determine the difference between multiple Cron triggers.
Though one wonders if you are doing something different, why not use a different rule?
I’m writing a rule to calculate my house power consumption.
I have had an Item with my meters instantaneous KW consumption, updated every 2s, that I now want to do something useful with, incentive growing since electrical hourly spot power prices here in the southern part of Norway has almost quadrupled this nov/dec.
So, I want to keep track of my consumption. Already having the KWs value, I want the calculate the KWminute/hour/day/week and month values as well. Just seemed natural for me to do it in one rule.
I also have a scraper providing next day hourly spot prices, so I can automatically shut off heating during a particularly expensive period. (my electrical bill for november was north of $550)
It is not bad to raise the power cost awareness, so a HABpanel screen is next I guess.
One unnatural side effect though is as configured, at the top of the hour the rule is triggered three times in a row, once for each cron trigger.
And I’m not sure what the every second trigger does for you. It might make more sense to change that to trigger on changes to your power Item instead.
Are you using Persistence to do the calculation? If not I suggested looking into that.
For simplicity sake, I’d probably split this into multiple rules. For UI rules, I find making rules that do one thing to be easier to maintain in the long run. If there is a lot of shared code, is out them into a library. I also make heavy use of conditions so by the time the script action runs all the error checking had been done.
I ended up peristing kwh/min and derives the rest from that:
I was not able to find any good examples for the history.sumSince() on this forum, so someone might find that useful: My hourly cost calculations are still WIP.
Script called by cron every 1s.
var today = new Date
var instPower = parseInt(items.getItem("GTV7PowerConsumption").state, 10)
var kwMinute
var hasTickedMinutes
var hourlyPrice
if (isNaN(kwMinute)) {
console.log("Rule starting");
kwMinute = 0;
kwHour = 0;
hasTickedMinutes = false
hourlyPrice = 0.0
function isMinuteTick () {
return (today.getSeconds() == 0)
function isHourTick () {
return (today.getMinutes() == 0 && today.getSeconds() == 4) // delay a bit so that the last persisted value becomes part of the sum
function isDayTick () {
return (today.getHours() == 0 && today.getMinutes() == 0 && today.getSeconds() == 4) // delay a bit so that the last persisted value becomes part of the sum
function isWeekTick () {
return (today.getDay() == 1 /* monday */ && isDayTick())
function isMonthTick () {
return (today.getDate() == 1 && isDayTick())
function isYearTick () {
return (today.getMonth() == 0 && isMonthTick()) // month 0 is January
function calcHourlyConsumptionCost(hourlyConsumption) {
// fetch NordPool hourly price for this hour interval
switch (today.getHours()) {
case 0:
hourlyPrice = parseFloat(items.getItem("toDay24_01").state)
break
case 1:
hourlyPrice = parseFloat(items.getItem("toDay01_02").state)
break
case 2:
hourlyPrice = parseFloat(items.getItem("toDay02_03").state)
break
case 3:
hourlyPrice = parseFloat(items.getItem("toDay03_04").state)
break
case 4:
hourlyPrice = parseFloat(items.getItem("toDay04_05").state)
break
case 5:
hourlyPrice = parseFloat(items.getItem("toDay05_06").state)
break
case 6:
hourlyPrice = parseFloat(items.getItem("toDay06_07").state)
break
case 7:
hourlyPrice = parseFloat(items.getItem("toDay07_08").state)
break
case 8:
hourlyPrice = parseFloat(items.getItem("toDay08_09").state)
break
case 9:
hourlyPrice = parseFloat(items.getItem("toDay09_10").state)
break
case 10:
hourlyPrice = parseFloat(items.getItem("toDay10_11").state)
break
case 11:
hourlyPrice = parseFloat(items.getItem("toDay11_12").state)
break
case 12:
hourlyPrice = parseFloat(items.getItem("toDay12_13").state)
break
case 13:
hourlyPrice = parseFloat(items.getItem("toDay13_14").state)
break
case 14:
hourlyPrice = parseFloat(items.getItem("toDay14_15").state)
break
case 15:
hourlyPrice = parseFloat(items.getItem("toDay15_16").state)
break
case 16:
hourlyPrice = parseFloat(items.getItem("toDay16_17").state)
break
case 17:
hourlyPrice = parseFloat(items.getItem("toDay17_18").state)
break
case 18:
hourlyPrice = parseFloat(items.getItem("toDay18_19").state)
break
case 19:
hourlyPrice = parseFloat(items.getItem("toDay19_20").state)
break
case 20:
hourlyPrice = parseFloat(items.getItem("toDay20_21").state)
break
case 21:
hourlyPrice = parseFloat(items.getItem("toDay21_22").state)
break
case 22:
hourlyPrice = parseFloat(items.getItem("toDay22_23").state)
break
case 23:
hourlyPrice = parseFloat(items.getItem("toDay23_24").state)
break
default:
hourlyPrice = 0.0
break
console.log("hourlyPrice=(NOK) " + (hourlyPrice*hourlyConsumption)/1000)
if (isMinuteTick()) {
if (!hasTickedMinutes) { // sample a full interval
hasTickedMinutes = true
} else {
kwMinute /= 60
//console.log("kWmin= " + kwMinute);
items.getItem("kWHminuteConsumption").postUpdate(kwMinute)
kwMinute = 0
} else {
kwMinute += instPower
if (isHourTick()) {
var kwPeriod = items.getItem("kWHminuteConsumption").history.sumSince(new Date(new Date().setHours(new Date().getHours()-1))) / 60
console.log("kWh= " + kwPeriod);
calcHourlyConsumptionCost(kwPeriod)
items.getItem("kWHhourlyConsumption").postUpdate(kwPeriod)
if (isDayTick()) {
var kwPeriod = items.getItem("kWHhourlyConsumption").history.sumSince(new Date(new Date().setDate(new Date().getDate()-1)))
console.log("kwhday=" + kwPeriod)
items.getItem("kWHdaylyConsumption").postUpdate(kwPeriod)
if (isWeekTick()) {
var kwPeriod = items.getItem("kWHdaylyConsumption").history.sumSince(new Date(new Date().setDate(new Date().getDate()-7)))
items.getItem("kWHweeklyConsumption").postUpdate(kwPeriod)
if (isMonthTick()) {
var kwPeriod = items.getItem("kWHhourlyConsumption").history.sumSince(new Date(new Date().setMonth(new Date().getMonth()-1)))
console.log("kwhmonth=" + kwPeriod)
items.getItem("kWHmonthlyConsumption").postUpdate(kwPeriod)
if (isYearTick()) {
var kwPeriod = items.getItem("kWHhourlyConsumption").history.sumSince(new Date(new Date().setMonth(new Date().getMonth()-12)))
console.log("kwhyear=" + kwPeriod)
items.getItem("kWHyearlyConsumption").postUpdate(kwPeriod)
