I’ve had read several threads about this, and nothing seems to apply here.
I had some cfg from v2 which now im using on a new install for v3.1.
I see the openhab3 reaching and connecting in the mysql, but he isn’t creating tables.
| 654713 | openhab | 192.168.1.247:40174 | openhab3 | Sleep | 167 | | NULL | 0.000 |
| 654714 | openhab | 192.168.1.247:40176 | openhab3 | Sleep | 31 | | NULL | 0.000 |
| 654715 | openhab | 192.168.1.247:40178 | openhab3 | Sleep | 167 | | NULL | 0.000 |
I see lots of errors like:
2021-08-08 19:22:16.129 [WARN ] [.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying d
irect instantiation.
Which as I understood in other threads its most likely not something that will stop him, but then later, there is:
2021-08-08 19:22:18.537 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@69c50678': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
java.lang.ClassCastException: class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
at org.openhab.persistence.jdbc.db.JdbcMysqlDAO.doPingDB(JdbcMysqlDAO.java:95) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.pingDB(JdbcMapper.java:72) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.checkDBAccessability(JdbcMapper.java:211) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:163) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
this one seems to be repeating everytime he tries to write on the database.
I already created the DB with UTF8 using:
create database openhab3 character set utf8 collate utf8_bin;
but he won’t create any tables.
anyone have seen that?
