- Platform information:
- Hardware: VM ware instance using 6 vCPUs and 8BG of RAM
- OS: Unbuntu v 20.04.4.
- MYSQL version 8.0.21
- Java Runtime Environment: V8
- openHAB version: 2.5.7.1
- Issue of the topic: JDBC Persistence is failing
I have been successfully able to get the mysql persistence working without issue. However, I have been trying to switch to the JDBC connection for added flexibility and it is failing. I have was researching this on and off for most of yesterday and while I found a few folks getting similar errors none of the resolutions worked.
I am receiving this error at the moment.
2020-08-19 12:32:18.118 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-08-19 12:32:18.119 [WARN ] [.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
2020-08-19 12:32:18.122 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:1.14.0 (229)[org.openhab.persistence.jdbc(231)] : The activate method has thrown an exception
com.zaxxer.hikari.pool.HikariPool$PoolInitializationException: Failed to initialize pool: Communications link failureThe last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server
Any information would be helpful or even a direction to go next. I have included the content of my jdbc.cfg and the logs below.
############################ JDBC Persistence Service ##################################
# I N S T A L L J D B C P E R S I S T E N C E S E R V I C E
# https://github.com/openhab/openhab/wiki/JDBC-Persistence
# Tested databases/url-prefix: jdbc:derby, jdbc:h2, jdbc:hsqldb, jdbc:mariadb, jdbc:mysql, jdbc:postgresql, jdbc:sqlite
# derby, h2, hsqldb, sqlite can be embedded,
# If no database is available it will be created, for example the url 'jdbc:h2:./testH2' creates a new DB in OpenHab Folder.
# Create new database, for example on a MySQL-Server use:
# CREATE DATABASE 'yourDB' CHARACTER SET utf8 COLLATE utf8_general_ci;
# D A T A B A S E C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
#url=jdbc:mariadb://10.0.0.16:3306/openhab
url=jdbc:mysql://10.0.0.16:3306/openhab
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
# url=jdbc:sqlite:./testSqlite.db
# url=
# required database user
user=myuser
# required database password
password=mypass
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
#errReconnectThreshold=
# I T E M O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
#sqltype.CALL = VARCHAR(200)
#sqltype.COLOR = VARCHAR(70)
#sqltype.CONTACT = VARCHAR(6)
#sqltype.DATETIME = DATETIME
#sqltype.DIMMER = TINYINT
#sqltype.LOCATION = VARCHAR(30)
#sqltype.NUMBER = DOUBLE
#sqltype.ROLLERSHUTTER = TINYINT
#sqltype.STRING = VARCHAR(65500)
#sqltype.SWITCH = VARCHAR(6)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
#numberDecimalcount=
# T A B L E O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
#tableNamePrefix=Item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
tableUseRealItemNames=true
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
#tableIdDigitCount=
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
#rebuildTableNames=true
# D A T A B A S E C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
#enableLogTime=true
`2020-08-19 15:36:02.300 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing 'zwave:serial_zstick:89cb5215' takes more than 5000ms.
2020-08-19 15:36:02.467 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2020-08-19 15:36:02.478 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2020-08-19 15:36:02.485 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2020-08-19 15:36:02.499 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-08-19 15:36:02.525 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2020-08-19 15:36:12.553 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'jdbc.persist'
2020-08-19 15:36:13.441 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-08-19 15:36:13.890 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.0.0.16:8080
2020-08-19 15:36:13.891 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.0.0.16:8443
2020-08-19 15:36:14.161 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-08-19 15:36:14.187 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-08-19 15:36:14.209 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-08-19 15:36:14.493 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-08-19 15:36:14.507 [WARN ] [.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
2020-08-19 15:36:14.585 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:1.14.0 (229)[org.openhab.persistence.jdbc(231)] : The activate method has thrown an exception
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
at com.zaxxer.hikari.pool.HikariPool.checkFailFast(HikariPool.java:516) ~[?:?]
at com.zaxxer.hikari.pool.HikariPool.<init>(HikariPool.java:118) ~[?:?]
at com.zaxxer.hikari.HikariDataSource.<init>(HikariDataSource.java:71) ~[?:?]
at org.knowm.yank.YankPoolManager.createPool(YankPoolManager.java:101) ~[?:?]
at org.knowm.yank.YankPoolManager.addDefaultConnectionPool(YankPoolManager.java:69) ~[?:?]
at org.knowm.yank.Yank.setupDefaultConnectionPool(Yank.java:705) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.openConnection(JdbcMapper.java:175) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.pingDB(JdbcMapper.java:53) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.checkDBAccessability(JdbcMapper.java:199) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.updateConfig(JdbcPersistenceService.java:222) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.activate(JdbcPersistenceService.java:65) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_265]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_265]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_265]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_265]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
at java.security.AccessController.doPrivileged(Native Method) [?:1.8.0_265]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [bundleFile:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
Caused by: com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
at com.mysql.cj.jdbc.exceptions.SQLError.createCommunicationsException(SQLError.java:174) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:64) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:835) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:455) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:240) ~[?:?]
at com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:207) ~[?:?]
at com.zaxxer.hikari.util.DriverDataSource.getConnection(DriverDataSource.java:95) ~[?:?]
at com.zaxxer.hikari.pool.PoolBase.newConnection(PoolBase.java:316) ~[?:?]
at com.zaxxer.hikari.pool.HikariPool.checkFailFast(HikariPool.java:506) ~[?:?]
... 83 more
Caused by: com.mysql.cj.exceptions.CJCommunicationsException: Communications link failure
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:1.8.0_265]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:1.8.0_265]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:1.8.0_265]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:1.8.0_265]
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:61) ~[?:?]
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:105) ~[?:?]
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:151) ~[?:?]
at com.mysql.cj.exceptions.ExceptionFactory.createCommunicationsException(ExceptionFactory.java:167) ~[?:?]
at com.mysql.cj.protocol.a.NativeSocketConnection.connect(NativeSocketConnection.java:91) ~[?:?]
at com.mysql.cj.NativeSession.connect(NativeSession.java:152) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:955) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:825) ~[?:?]
... 83 more
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_265]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_265]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_265]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_265]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_265]
at java.net.Socket.connect(Socket.java:607) ~[?:1.8.0_265]
at com.mysql.cj.protocol.StandardSocketFactory.connect(StandardSocketFactory.java:155) ~[?:?]
at com.mysql.cj.protocol.a.NativeSocketConnection.connect(NativeSocketConnection.java:65) ~[?:?]
... 83 more
2020-08-19 15:36:14.601 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-08-19 15:36:14.602 [WARN ] [.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
2020-08-19 15:36:14.603 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:1.14.0 (229)[org.openhab.persistence.jdbc(231)] : The activate method has thrown an exception
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
... 92 more
... 92 more
... 92 more
2020-08-19 15:36:14.614 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-08-19 15:36:14.614 [WARN ] [.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
2020-08-19 15:36:14.616 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:1.14.0 (229)[org.openhab.persistence.jdbc(231)] : The activate method has thrown an exception
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:756) [bundleFile:?]
