Yes i see this:
14:42:56.564 [DEBUG] [tence.jdbc.internal.JdbcConfiguration] - JDBC::updateConfig: errReconnectThreshold=1
So I try to set reconnectCnt=0
? I’ll report back
Yes i see this:
? I’ll report back
Hey Mark
A miracle has happened, JDBC is writing to the database you made my day!!! I tried hours and days without any clue, thank you so much!!!
But please can you explain me this behavior? The only thing, which I see now, is that it will probably create new items for my exiting ones, because of the Item vs item issue and the 00 in front of the numbers of the items, where there are none with the old mysql service
Even though you deleted the jdbc.config
file in the userdata directory, I suspect it was still recreated with the same reconnectCnt=1
value. Since that parameter wasn’t specified in your jdbc.cfg
file, it continued to use the value in the shadow config file until you overrode it by setting it explicitly.
Ok thank you very much!
Is the item vs Item issue also solvable as well as the 00 in front of the item numbers?
No problem. Glad we got it sorted out.
Sorry, I don’t know. I’m not familiar with that part of how the jdbc bundle works.
ok, no problem. Main is that database is working…
Hi all,
I have tested on the weekend to migrate from OH 2.5.12 to 3.1.0-M1 and I dont’ get any connection of the JDBC driver to the database. Find below the error entry from the log. It shows that the username is not passed to the driver to connect correctly
Failed to initialize pool: Access denied for user ''@'172.17.0.4' (using password: NO)
even though it worked without any problem on 2.5.12. I am wondering if the jump of the JAVA version from 8 to 11 may cause that the username is not parsed from the cfg file?
I have a jdbc.cfg
and even a mysql.cfg
in the services
directory and a jdbc.persist
and mysql.persist
in the persistence
directory.
And the jdbc-mysql
is loaded via the addons.cfg:
# A comma-separated list of persistence services to install (e.g. "rrd4j,jpa")
persistence = jdbc-mysql
Does anyone have a clue why the driver gets not loaded correctly?
14:57:46.394 [INFO ] [.persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
14:57:46.396 [WARN ] [m.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
14:57:46.401 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:3.1.0.M1 (249)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(305)] : The activate method has thrown an exception
com.zaxxer.hikari.pool.HikariPool$PoolInitializationException: Failed to initialize pool: Access denied for user ''@'172.17.0.4' (using password: NO)
at com.zaxxer.hikari.pool.HikariPool.checkFailFast(HikariPool.java:516) ~[?:?]
at com.zaxxer.hikari.pool.HikariPool.<init>(HikariPool.java:118) ~[?:?]
at com.zaxxer.hikari.HikariDataSource.<init>(HikariDataSource.java:71) ~[?:?]
at org.knowm.yank.YankPoolManager.createPool(YankPoolManager.java:101) ~[?:?]
at org.knowm.yank.YankPoolManager.addDefaultConnectionPool(YankPoolManager.java:69) ~[?:?]
at org.knowm.yank.Yank.setupDefaultConnectionPool(Yank.java:705) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.openConnection(JdbcMapper.java:187) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.pingDB(JdbcMapper.java:64) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.checkDBAccessability(JdbcMapper.java:211) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.updateConfig(JdbcPersistenceService.java:219) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.activate(JdbcPersistenceService.java:83) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
at java.security.AccessController.doPrivileged(Native Method) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi-3.12.100.jar:?]
Caused by: java.sql.SQLException: Access denied for user ''@'172.17.0.4' (using password: NO)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97) ~[?:?]
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:836) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:456) ~[?:?]
at com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:246) ~[?:?]
at com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:198) ~[?:?]
at com.zaxxer.hikari.util.DriverDataSource.getConnection(DriverDataSource.java:95) ~[?:?]
at com.zaxxer.hikari.pool.PoolBase.newConnection(PoolBase.java:316) ~[?:?]
at com.zaxxer.hikari.pool.HikariPool.checkFailFast(HikariPool.java:506) ~[?:?]
... 92 more
Does the user name in the Cfg exist in mysql (CREATE USER, GRANT all Privileges, etc. )? Maybe it was lost in the conversion. If that was lost, maybe you need to create the CREATE DATABASE , etc. too. Just a thought.
Bob
Hi all,
I found the reasons for my jdbc login problems. The syntax in the jdbc.cfg file was wrong. It seems to work with OH2.5 but obviously caused problems with OH3:
Previous syntax:
# required database user
mysql:user=XXX
# required database password
mysql:password=YYY
mysql:default_time_zone='Europe/Berlin'
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
#errReconnectThreshold=0
mysql:reconnectCnt=3
mysql:waitTimeout=28800
New syntax working:
user=XXX
password=YYY
reconnectCnt=3
waitTimeout=28800
After having solved my primary issue … The second one is just following. It looks like the data format is different. I do not understand if this fits to the issue of the changed data format of the timestamps mentioned above … But may I am completely wrong. Hence any advice about this error behaviour would be kindly appreciated:
14:43:19.895 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
java.lang.ClassCastException: class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
at org.openhab.persistence.jdbc.db.JdbcMysqlDAO.doPingDB(JdbcMysqlDAO.java:95) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.pingDB(JdbcMapper.java:72) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:163) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
14:43:19.913 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.922 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.927 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.937 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.941 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.953 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.956 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.966 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.978 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:19.994 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.008 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.019 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.023 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.033 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.055 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.067 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.087 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.096 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.100 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
14:43:20.112 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@58234126': class java.lang.Integer cannot be cast to class java.lang.Long (java.lang.Integer and java.lang.Long are in module java.base of loader 'bootstrap')
In “stackoverflow.com” there is the following solution proposed:
Change long getId() to int getId();
I have the exact same issue, i have even tried with a new database with no luck.
Did any Item change state just before this happened? If so, which type has the Item? I’m thinking the reason why it works fine for some of us (like me) and not for you might be because you have Items which int values (like for example dimmers) and this happens when it tries to persist them…
@DanielMalmgren,
can you please explain a bit more in detail what you mean when you say that “Items int values”???
Well, exactly what I said. For example a dimmer. Those values are saved as integer values, for example 37 or 63. I have no Items in my system that saves anything as integers.
Hi @DanielMalmgren,
I fear you might not like my response. I learned that some item data types changed in the migration from OH V2.5 to OH V3.x this means for example that some items changed from int to double_int or to float and when OH 3 tries to write the item with its new data type to the “old” database with the old data type it fails and throws these errors (at least that is my interpretation of this error message). And hence I simply created a new empty database in MariaDB for OH V3 and let OH create new tables and entries and the new persistence is stored to the new database. I keep the old data in the old database and when I do a historic query I do it manually into the old database.
I think there is no other way unless you are a MariaDB specialist and you know how to convert the data types in the affected tables.
Hi Mark
It is me again. thanks to your help JDBC worked with mariadb5. Now, since I want to upgrade my synology to DSM 7.0, which only supports mariadb10 I need to change to mariadb10.
Of course JDBC does not work with mariadb10 (I changee port to 3307). It does not connect at all:
19:43:36.343 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:3.0.1 (276)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(323)] : The activate method has thrown an exception
com.zaxxer.hikari.pool.HikariPool$PoolInitializationException: Failed to initialize pool: Could not connect to address=(host=192.168.xxx.xx)(port=3307)(type=master) : Connection refused (Connection refused)
Do you have any idea what is wrong here?
thanks in advance!!
I’m sorry, but I don’t know anything about mariadb10 (I’m using mysql), and what the issues might be using the JDBC binding with mariadb10.
Did you change the port here it is commented out by default:
[server]
# this is only for the mysqld standalone daemon
[mysqld]
# * Basic Settings
user = mysql
pid-file = /run/mysqld/mysqld.pid
socket = /run/mysqld/mysqld.sock
#port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc-messages-dir = /usr/share/mysql
#skip-external-locking
The file is: /etc/mysql/mariadb.conf.d/50-server.cnf
Then restart the database. sudo systemctl restart mysqld.service
Run this:
sudo netstat -tunlp |grep 3307
you should see this:
tcp 0 0 127.0.0.1:3307 0.0.0.0:* LISTEN 985/mysqld
Hi, Thanks for the reply. I have the db installed on my synology NAS. I have not found a file such as /etc/mysql/mariadb.conf.d/50-server.cnf…
ok, I changed the conf to mysql, i.e. conf file looks like this:
url=jdbc:mysql://192.168.xxx.xx:3307/openhab?serverTimezone=Europe/Berlin
and I installed the JDBC Persistence MySQL on openHAB. Now I get the following error:
06:41:05.103 [WARN ] [m.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
06:41:05.125 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:3.0.1 (276)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(338)] : The activate method has thrown an exception
com.zaxxer.hikari.pool.HikariPool$PoolInitializationException: Failed to initialize pool: Communications link failure
Would you have here an idea?
