JDBC Mysql persistence in OH3
There is a dedicated JDBC binding for MariaDB
You should use that and not the one for MySQL …
MariadDB 10 was already available on Synology with DSM V6. I migrated already years ago from V5 to V10 without any trouble. With OpenHAB V3 it is important to have the right persistence binding (I have used the mysql binding before as well)!
Hi Justus
Thank you for your reply. I’m happy that at least somebody has a working set-up with mariaDB10.
I was already aware that one should install the dedicated JDBC binding for MariaDB. I could not connect with this either. I always get following error message:
21:54:23.467 [ERROR] [.jdbc.internal.JdbcPersistenceService] - bundle org.openhab.persistence.jdbc:3.1.0 (287)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(347)] : The activate method has thrown an exception
com.zaxxer.hikari.pool.HikariPool$PoolInitializationException: Failed to initialize pool: Could not connect to address=(host=192.168.xxx.xx)(port=3307)(type=master) : Connection refused (Connection refused)
My jdbc.cfg setting is:
url=jdbc:mariadb://192.168.xxx.xx:3307/openhab
user=xxxxx
password=xxxxxx
reconnectCnt=0
What kind of setting do you have? Any other ideas?
Thank you in advance for any hint
@Logos Hi Rolf,
I assume you are also running OH 3.1, right? It is not clear to me which change caused the trouble the upgrade to OH 3 or the move from mariadb5 to mariadb10. It looks to me that you made two changes at once?
Here is my jdbc.cfg:
url=jdbc:mariadb://<ip_address>:3307/<mariadb_name>?useLegacyDatetimeCode=false&serverTimezone=Europe/Berlin
user=xxx
password=yyy
default_time_zone='Europe/Berlin'
reconnectCnt=0
waitTimeout=28800
sqltype.LOCATION      =   VARCHAR(256)
sqltype.STRING         =   VARCHAR(4096)
sqltype.IMAGE          =   BLOB
Did you create a new database in MariaDB10 or did you move your old database from v5 to V10?
When you migrate from OH2.5 to OH3 you should definitely create a new database following these instructions:
Somewhere in the web there is also a description how to exactly do it on a Synology NAS when leveraging the phpMyAdmin app that you can install from the Synology community. It creates the empty database with all required grants and rights.
Hi Justus
I’m on OH 3,1 stable. The problem only occurred since I wanted to change from mariaBD5 to mariaDB10 (since I want to upgrade synology to DSM 7.0 and mariaDB5 is not supported anymore on DSM 7.0)
I took all your settings from your cfg file. I installed mariaDB10 again from scratch. However I still get following error messages:
17:18:29.509 [ERROR] [.jdbc.internal.JdbcPersistenceService] - bundle org.openhab.persistence.jdbc:3.1.0 (287)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(347)] : The activate method has thrown an exception
it is quite frustrating. Do you have any idea?
Best regards
Rolf
does the DB listen on 192.168.xxx.xx on port 3307 or on the localhost ( 127.0.0.1 ) only ?
Maybe you have some orphan bindings running :thinking: … what does the output say of:
openhab> list -s | grep jdbc
openhab> list -s | grep mariadb
openhab> list -s | grep mysql
Can you login to the database via the NAS command line:
cd /volumeX/@appstore/MariaDB10/usr/local/mariadb10/bin
./mysql -u <your_user> -p <your_user_password>
Did you check the box “TCP/IP Verbindung aktivieren” in the MariaDB configuration that you can start from the Synology “Main Menu” => “MariaDB 10” ???
Yeah … maybe try using:
url=jdbc:mariadb://127.0.0.1:3307/openhab
instead of:
Hi Justus
I feel quite stupid now: the thing was that I did not check the box “TCP/IP Verbindung aktivieren”. Sorry that I I did take your time (and the time of @Wolfgang_S) for such a stupid mistake.
In any case I thank you so much having taken the time to help me.
@Logos Hi Rolf,
no worries! That is what communities are for :yum:
We all benefit from sharing our knowledge. Maybe the next time you help me solving my “stupid” question :rofl: (as there are not stupid questions!!!)
Hi there,
I finally upgraded from 2.5 to 3.1 last Sunday and am busy ironing out issues since then.
What I have not been able to fix so far is the persistence with my MySQL database. This worked perfectly fine with 2.5.1.
What I get in the log-file is:
2021-12-08 14:45:01.143 [ERROR] [jdbc.internal.JdbcPersistenceService] - bundle org.openhab.persistence.jdbc:3.1.0 (285)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(295)] : The activate method has thrown an exception
java.lang.NumberFormatException: For input string: "1.0"
	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
	at java.lang.Integer.parseInt(Integer.java:652) ~[?:?]
	at java.lang.Integer.parseInt(Integer.java:770) ~[?:?]
	at org.openhab.persistence.jdbc.internal.JdbcConfiguration.updateConfig(JdbcConfiguration.java:142) ~[?:?]
	at org.openhab.persistence.jdbc.internal.JdbcConfiguration.<init>(JdbcConfiguration.java:73) ~[?:?]
	at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.updateConfig(JdbcPersistenceService.java:218) ~[?:?]
	at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.activate(JdbcPersistenceService.java:83) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:244) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:685) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:529) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:318) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:308) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:354) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216) [org.eclipse.osgi-3.16.200.jar:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656) [org.eclipse.osgi-3.16.200.jar:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496) [org.eclipse.osgi-3.16.200.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
2021-12-08 14:45:01.316 [WARN ] [ence.internal.PersistenceManagerImpl] - bundle org.openhab.core.persistence:3.1.0 (215)[org.openhab.core.persistence.internal.PersistenceManagerImpl(217)] : Could not get service from ref {org.openhab.core.persistence.PersistenceService, org.openhab.core.persistence.QueryablePersistenceService}={service.id=526, service.bundleid=285, service.scope=bundle, user=openHAB, url=jdbc:mysql://10.0.1.10:3306/openHAB?useSSL=false&serverTimezone=Europe/Vienna, component.name=org.openhab.persistence.jdbc.internal.JdbcPersistenceService, reconnectCnt=1.0, service.config.label=JDBC Persistence Service, component.id=295, service.config.factory=false, password=oHsql2015$, errReconnectThreshold=3, service.config.category=persistence, serverTimezone=Europe/Vienna, service.config.description.uri=persistence:jdbc, service.pid=[org.openhab.jdbc, org.openhab.jdbc]}
2021-12-08 14:45:01.317 [WARN ] [ence.internal.PersistenceManagerImpl] - bundle org.openhab.core.persistence:3.1.0 (215)[org.openhab.core.persistence.internal.PersistenceManagerImpl(217)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.persistence.PersistenceService, org.openhab.core.persistence.QueryablePersistenceService}={service.id=526, service.bundleid=285, service.scope=bundle, user=openHAB, url=jdbc:mysql://10.0.1.10:3306/openHAB?useSSL=false&serverTimezone=Europe/Vienna, component.name=org.openhab.persistence.jdbc.internal.JdbcPersistenceService, reconnectCnt=1.0, service.config.label=JDBC Persistence Service, component.id=295, service.config.factory=false, password=oHsql2015$, errReconnectThreshold=3, service.config.category=persistence, serverTimezone=Europe/Vienna, service.config.description.uri=persistence:jdbc, service.pid=[org.openhab.jdbc, org.openhab.jdbc]} for reference PersistenceService
2021-12-08 14:45:01.318 [ERROR] [jdbc.internal.JdbcPersistenceService] - bundle org.openhab.persistence.jdbc:3.1.0 (285)[org.openhab.persistence.jdbc.internal.JdbcPersistenceService(295)] : The activate method has thrown an exception
2021-12-08 14:45:01.320 [WARN ] [ernal.PersistenceServiceRegistryImpl] - bundle org.openhab.core.persistence:3.1.0 (215)[org.openhab.core.persistence.internal.PersistenceServiceRegistryImpl(218)] : Could not get service from ref {org.openhab.core.persistence.PersistenceService, org.openhab.core.persistence.QueryablePersistenceService}={service.id=526, service.bundleid=285, service.scope=bundle, user=openHAB, url=jdbc:mysql://10.0.1.10:3306/openHAB?useSSL=false&serverTimezone=Europe/Vienna, component.name=org.openhab.persistence.jdbc.internal.JdbcPersistenceService, reconnectCnt=1.0, service.config.label=JDBC Persistence Service, component.id=295, service.config.factory=false, password=oHsql2015$, errReconnectThreshold=3, service.config.category=persistence, serverTimezone=Europe/Vienna, service.config.description.uri=persistence:jdbc, service.pid=[org.openhab.jdbc, org.openhab.jdbc]}
2021-12-08 14:45:01.320 [WARN ] [ernal.PersistenceServiceRegistryImpl] - bundle org.openhab.core.persistence:3.1.0 (215)[org.openhab.core.persistence.internal.PersistenceServiceRegistryImpl(218)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.persistence.PersistenceService, org.openhab.core.persistence.QueryablePersistenceService}={service.id=526, service.bundleid=285, service.scope=bundle, user=openHAB, url=jdbc:mysql://10.0.1.10:3306/openHAB?useSSL=false&serverTimezone=Europe/Vienna, component.name=org.openhab.persistence.jdbc.internal.JdbcPersistenceService, reconnectCnt=1.0, service.config.label=JDBC Persistence Service, component.id=295, service.config.factory=false, password=oHsql2015$, errReconnectThreshold=3, service.config.category=persistence, serverTimezone=Europe/Vienna, service.config.description.uri=persistence:jdbc, service.pid=[org.openhab.jdbc, org.openhab.jdbc]} for reference PersistenceService
2021-12-08 14:45:02.284 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 15f2f551-f92c-4602-91d5-bd2545a43185, base URL = http://localhost:8080)
My jdbc.cfg:
############################ JDBC Persistence Service ##################################
# I N S T A L L   J D B C   P E R S I S T E N C E   S E R V I C E
# https://github.com/openhab/openhab/wiki/JDBC-Persistence
# Tested databases/url-prefix: jdbc:derby, jdbc:h2, jdbc:hsqldb, jdbc:mariadb, jdbc:mysql, jdbc:postgresql, jdbc:sqlite
# derby, h2, hsqldb, sqlite can be embedded,
# If no database is available it will be created, for example the url 'jdbc:h2:./testH2' creates a new DB in OpenHab Folder.
# Create new database, for example on a MySQL-Server use:
# CREATE DATABASE 'yourDB' CHARACTER SET utf8 COLLATE utf8_general_ci;
# D A T A B A S E  C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
# url=jdbc:mariadb://192.168.0.1:3306/testMariadb
# url=jdbc:mysql://192.168.0.1:3306/testMysql
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
# url=jdbc:sqlite:./testSqlite.db
# url=
# required database user
user=mysqluser
# required database password
password=userspwd
# E R R O R   H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
# I T E M   O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
#sqltype.CALL          =   VARCHAR(200)
#sqltype.COLOR         =   VARCHAR(70)
#sqltype.CONTACT       =   VARCHAR(6)
#sqltype.DATETIME      =   DATETIME
#sqltype.DIMMER        =   TINYINT
#sqltype.LOCATION      =   VARCHAR(30)
#sqltype.NUMBER        =   DOUBLE
#sqltype.ROLLERSHUTTER =   TINYINT
#sqltype.STRING        =   VARCHAR(65500)
#sqltype.SWITCH        =   VARCHAR(6)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
#numberDecimalcount=
# T A B L E   O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
#tableNamePrefix=Item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
#tableUseRealItemNames=
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
#tableIdDigitCount=
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
#rebuildTableNames=true
# D A T A B A S E  C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
#enableLogTime=true
The jdbc.config file in the var-folder:
:org.apache.felix.configadmin.revision:=L"10"
errReconnectThreshold="3"
password="userspwd"
reconnectCnt="1.0"
serverTimezone="Europe/Vienna"
service.pid="org.openhab.jdbc"
url="jdbc:mysql://10.0.1.10:3306/openHAB?useSSL\=false&serverTimezone\=Europe/Vienna"
user="mysqluser"
I assume it is related with
reconnectCnt=“1.0”
But now sure what to do with it?
Many thanks for your help!
Regards
Matthias
Mine is set like this:
reconnectCnt=0
And where?
services/jdbc.cfg
OK. That entry wasn’t there at all.
Added it now and it seems work! So, big thanks for that!!
One caveat though: what about these errors I am getting now:
2021-12-08 22:42:15.251 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@6ade83e9': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
java.lang.ClassCastException: class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
	at org.openhab.persistence.jdbc.db.JdbcBaseDAO.objectAsInteger(JdbcBaseDAO.java:540) ~[?:?]
	at org.openhab.persistence.jdbc.db.JdbcBaseDAO.getState(JdbcBaseDAO.java:510) ~[?:?]
	at org.openhab.persistence.jdbc.db.JdbcBaseDAO.lambda$0(JdbcBaseDAO.java:344) ~[?:?]
	at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
	at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655) ~[?:?]
	at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
	at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913) ~[?:?]
	at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
	at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578) ~[?:?]
	at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:345) ~[?:?]
	at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) ~[?:?]
	at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-12-08 22:42:15.484 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
Again, many thanks for your help!!
Oh, that one has me stumped. Seems like the most relevant part of the stack trace is this. Is something querying historical item states? Totally a guess on my part…
Did you change item type from String to Number? If so you can have strings stored in database while actual readout expects an number…
You mean things like .lastUpdate in rules?
Yes, this I do use occasionally.
