So, I did get a chance to take a quick look at the logs. It looks like items in openhab are continuously sending value updates to the database up until they are not. The database is not throwing any errors that are abundantly obvious.
I assumed a database problem because of this image:
The critical points here are that nothing remarkable happened at or shortly after 16:00, however, I did restart openhab shortly after 20:00.
This looks βnormalβ to me (yes, yes, my regex skills stink):
openhab:/var/log/openhab$ cat /var/log/openhab/openhab.log.7 | grep DEBUG | grep "2021-04-09 16" | grep -E '(Ecobee_MasterBedroom_Temperature|item0019)'
2021-04-09 16:02:00.001 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.0 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:02:00.002 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:02:00.002 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:02:00.002 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.0 Β°F'
2021-04-09 16:02:00.002 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.0'
2021-04-09 16:02:00.005 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.0 Β°F' in SQL database at Fri Apr 09 16:02:00 EDT 2021 in 4 ms.
2021-04-09 16:07:15.647 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=70.9 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:07:15.647 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:07:15.647 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:07:15.647 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '70.9 Β°F'
2021-04-09 16:07:15.648 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='70.9'
2021-04-09 16:07:15.651 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '70.9 Β°F' in SQL database at Fri Apr 09 16:07:15 EDT 2021 in 4 ms.
2021-04-09 16:08:51.029 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=70.7 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:08:51.029 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:08:51.030 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:08:51.030 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '70.7 Β°F'
2021-04-09 16:08:51.030 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='70.7'
2021-04-09 16:08:51.032 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '70.7 Β°F' in SQL database at Fri Apr 09 16:08:51 EDT 2021 in 3 ms.
2021-04-09 16:12:00.630 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=70.9 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:12:00.630 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:12:00.630 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:12:00.630 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '70.9 Β°F'
2021-04-09 16:12:00.630 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='70.9'
2021-04-09 16:12:00.642 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '70.9 Β°F' in SQL database at Fri Apr 09 16:12:00 EDT 2021 in 12 ms.
2021-04-09 16:18:18.960 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.2 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:18:18.960 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:18:18.960 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:18:18.960 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.2 Β°F'
2021-04-09 16:18:18.960 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.2'
2021-04-09 16:18:18.964 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.2 Β°F' in SQL database at Fri Apr 09 16:18:18 EDT 2021 in 5 ms.
2021-04-09 16:21:28.648 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.6 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:21:28.649 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:21:28.649 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:21:28.649 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.6 Β°F'
2021-04-09 16:21:28.649 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.6'
2021-04-09 16:21:28.652 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.6 Β°F' in SQL database at Fri Apr 09 16:21:28 EDT 2021 in 4 ms.
2021-04-09 16:22:31.993 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.3 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:22:31.993 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:22:31.993 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:22:31.993 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.3 Β°F'
2021-04-09 16:22:31.994 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.3'
2021-04-09 16:22:31.997 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.3 Β°F' in SQL database at Fri Apr 09 16:22:31 EDT 2021 in 4 ms.
2021-04-09 16:24:38.153 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.6 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:24:38.153 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:24:38.154 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:24:38.154 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.6 Β°F'
2021-04-09 16:24:38.154 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.6'
2021-04-09 16:24:38.156 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.6 Β°F' in SQL database at Fri Apr 09 16:24:38 EDT 2021 in 3 ms.
2021-04-09 16:30:57.110 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.2 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:30:57.111 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:30:57.111 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:30:57.111 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.2 Β°F'
2021-04-09 16:30:57.111 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.2'
2021-04-09 16:30:57.114 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.2 Β°F' in SQL database at Fri Apr 09 16:30:57 EDT 2021 in 4 ms.
2021-04-09 16:37:16.325 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=70.9 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:37:16.325 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:37:16.325 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:37:16.325 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '70.9 Β°F'
2021-04-09 16:37:16.325 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='70.9'
2021-04-09 16:37:16.328 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '70.9 Β°F' in SQL database at Fri Apr 09 16:37:16 EDT 2021 in 3 ms.
2021-04-09 16:37:48.201 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=71.1 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:37:48.201 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:37:48.201 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:37:48.201 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '71.1 Β°F'
2021-04-09 16:37:48.201 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='71.1'
2021-04-09 16:37:48.204 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '71.1 Β°F' in SQL database at Fri Apr 09 16:37:48 EDT 2021 in 3 ms.
2021-04-09 16:42:00.350 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::storeItemValue: item=Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=70.9 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])
2021-04-09 16:42:00.350 [DEBUG] [penhab.persistence.jdbc.model.ItemVO] - JDBC:ItemVO tableName=item0019; newTableName=null;
2021-04-09 16:42:00.350 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getItemType: Try to use ItemType NUMBERITEM for Item Ecobee_MasterBedroom_Temperature
2021-04-09 16:42:00.350 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::storeItemValueProvider: item 'Ecobee_MasterBedroom_Temperature' as Type 'NUMBERITEM' in 'item0019' with state '70.9 Β°F'
2021-04-09 16:42:00.350 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doStoreItemValue sql=INSERT INTO item0019 (TIME, VALUE) VALUES( NOW(), CAST( ? as DOUBLE PRECISION) ) value='70.9'
2021-04-09 16:42:00.355 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC: Stored item 'Ecobee_MasterBedroom_Temperature' as '70.9 Β°F' in SQL database at Fri Apr 09 16:42:00 EDT 2021 in 5 ms.
I think this is the log that produced image/chart/screenshot above.
2021-04-09 23:32:28.399 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is Ecobee_MasterBedroom_Temperature
2021-04-09 23:32:28.399 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDecimalcount='3' table='item0019' item='Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=67.6 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])' itemName='Ecobee_MasterBedroom_Temperature'
2021-04-09 23:32:28.400 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::getHistItemFilterQueryProvider filter = org.openhab.core.persistence.FilterCriteria@4f6ce487, numberDecimalcount = 3, table = item0019, simpleName = Ecobee_MasterBedroom_Temperature
2021-04-09 23:32:28.400 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::query queryString = SELECT time, value FROM item0019 WHERE TIME<'2021-04-09 11:32:28' ORDER BY time DESC OFFSET 0 LIMIT 1
2021-04-09 23:32:28.400 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value FROM item0019 WHERE TIME<'2021-04-09 11:32:28' ORDER BY time DESC OFFSET 0 LIMIT 1
2021-04-09 23:32:28.402 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.402 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: query for Ecobee_MasterBedroom_Temperature returned 1 rows in 3 ms
2021-04-09 23:32:28.402 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is Ecobee_MasterBedroom_Temperature
2021-04-09 23:32:28.403 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDecimalcount='3' table='item0019' item='Ecobee_MasterBedroom_Temperature (Type=NumberItem, State=67.6 Β°F, Label=Temperature, Category=Temperature, Groups=[gRemoteSensors, F2_MasterBedroom, gF2_MasterBedroom_HVAC])' itemName='Ecobee_MasterBedroom_Temperature'
2021-04-09 23:32:28.403 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::getHistItemFilterQueryProvider filter = org.openhab.core.persistence.FilterCriteria@4f6ce487, numberDecimalcount = 3, table = item0019, simpleName = Ecobee_MasterBedroom_Temperature
2021-04-09 23:32:28.403 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::query queryString = SELECT time, value FROM item0019 WHERE TIME>'2021-04-09 11:32:28' AND TIME<'2021-04-09 23:32:28' ORDER BY time ASC
2021-04-09 23:32:28.403 [DEBUG] [ersistence.jdbc.db.JdbcPostgresqlDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value FROM item0019 WHERE TIME>'2021-04-09 11:32:28' AND TIME<'2021-04-09 23:32:28' ORDER BY time ASC
2021-04-09 23:32:28.406 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.407 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.407 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.407 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.407 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.407 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.408 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.408 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.408 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.408 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.408 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.409 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.409 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.409 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.409 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.409 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.410 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.410 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.410 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.410 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.410 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.411 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.411 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.411 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.411 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.411 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.412 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.412 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.412 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.412 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.412 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.412 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.413 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.413 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.413 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.413 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.413 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.414 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.414 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.414 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.414 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.415 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.415 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.415 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.415 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.415 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.415 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.416 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.416 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.416 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '72.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.416 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.416 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.416 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.417 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.417 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.417 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.417 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.417 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.418 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.418 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '70.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.418 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '71.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.418 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.418 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.419 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.419 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.419 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.419 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.419 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.420 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.420 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.420 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.420 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.420 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.420 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.421 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.421 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.421 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.421 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.9', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.421 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.421 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.422 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.422 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.422 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.422 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.423 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.423 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.423 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.423 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.424 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.424 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.424 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.5', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.424 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.424 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.425 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.425 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.7', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.425 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.425 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.0', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.425 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.3', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.426 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.1', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.426 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '68.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.426 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.426 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.2', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.426 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.4', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.427 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.8', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.427 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '67.6', getClass = 'class java.lang.Double', clazz = 'Double'
2021-04-09 23:32:28.427 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: query for Ecobee_MasterBedroom_Temperature returned 125 rows in 24 ms
There are no entries for the item after 16:42 until the restart around 20:12. Perhaps this is an error with the Ecobee sensors reporting inβ¦ Iβll chart some other sensors.
SixO
