As far as I can tell, OpenHAB is able to connect to Postgres. However, no tables are created. And my charts don’t show any datapoints (not sure if this is related).
psql output
postgres-# \c openhab
You are now connected to database "openhab" as user "postgres".
openhab-# \dt
Did not find any relations.
Furthermore, invoking jdbc reload on the OpenHAB console, fails with an exception:
openhab> jdbc reload
org.openhab.persistence.jdbc.internal.exceptions.JdbcSQLException: Error in SQL query!!!; ERROR: relation "items" does not exist
Position: 30 Query: SELECT ItemId, ItemName FROM items Parameters: []; Pool Name= yank-default; SQL= SELECT ItemId, ItemName FROM items
I confirmed the the related JDBC bundles are active:
openhab> bundle:list -s|grep -i JDBC
269 x Active x 80 x 4.1.1 x org.openhab.persistence.jdbc
270 x Active x 80 x 42.4.3 x org.postgresql.jdbc
I am stuck here. There seems to be no way to tell OpenHAB to create the database tables. I miss a jdbc re-initialize command that creates OpenHABs database tables.
On the other hand, I am not sure why there are no tables in the first place.
Feb 16 12:47:58 exmaple.org postgres[13363]: 2024-02-16 11:47:58.629 GMT [13363] ERROR: permission denied for schema public at character 28
Feb 16 12:47:58 example.org postgres[13363]: 2024-02-16 11:47:58.629 GMT [13363] STATEMENT: CREATE TABLE IF NOT EXISTS items (itemid SERIAL NOT NULL, ItemName VARCHAR(500) NOT NULL, CONSTRAINT items_pkey PRIMARY KEY (itemid))
The “permission denied for schema public at character 28” indicates a missing permission. And as it turns out, with Postgresql 15 the following is not sufficient to create the openhab database and provision the openhab user access:
postgres=# create database openhab;
postgres=# create user openhab with encrypted password 'mypass';
postgres=# grant all privileges on database openhab to openhab;
You now also have to
postgres=# \c openhab
openhab=# grant all on schema public to openhab;
Related Stackoverflow answer:
It would be great if OpenHAB would better signal database errors.
Unfortunately, I still don’t get any data in the database: no rows are created and there is a single table named ‘items’ (not sure if there are meant to be more tables).
I get
2024-02-16 13:53:26.736 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is Wandthermostat_Wohnzimmer_Humidity
2024-02-16 13:53:26.738 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: unable to find table for item with name: 'Wandthermostat_Wohnzimmer_Humidity', no data in database.
After configuring persistence for all items in my main group (“Indoor”) I know see that OpenHAB persists data in the database.
I was under the assumption that having a defaultStrategy specified would be sufficient to persist all items. I remember reading that somewhere in the documentation. However, this appears to be insufficient. I had to explicitly define persistence for items.
