Hello all together I am straight at the change of Fhem to OpenHAB2.
So now to my problem, I have a self-made Jeeling and a nanoCUL 433Mhz Intertechno.
With the nanoCUL I was able to switch my Intertechno IT-1500 sockets under Fhem and receive the temperature and humidity of my Lacrosse units with the Jeelink.
Have the Jeeling binding installed and configured as ttyUSB0, which runs under Openhabian (OpenHAB 2)
The binding for my CUL Intertechno I have also installed and configured but i can’t switch anything under openHAB 2
So items are created correctly, sitemaps too. The intertechno config I have also set in my log is can’t open CUL. It is as if the two sticks bite, so think the CUL is not ready since the Jeelink uses the serial interface. These two sticks have operated parallel under Fhem. Since I could however also the CUL directly over the FTDI serial number adjust thus / dev / serial / by-id / and since the serial number.
Can you please help me am really despairing.
My system is a Raspberry 3 with openhabian and the Jeelink Stick and CUL Stick. A Hue bridge is also configured and runs over openHAB 2.
I should notice that I am Linux newbee. Fhem I had only run about the instructions from the web.
Based on my( limited ) experience with linux, both sticks should be using a different serial port (only one at /dev/ttyS0. The config file of the Intertechno binding and the thing configuration for Jelink should reflect that.
I’m using a CUL only on my Raspi running Openhabian Besides the config thee was nothing else the set.
You have two serial devices so you have two serial interfaces.
The Jeelink should not have a effect to the CUL
Do you have set the cul device path in the culintertechno.cfg file ?
What do you see when you type: lsusb ?
What do you see when you type: dmesg | grep tty ?
If the jeelink is /dev/ttyUSB0 then the CUL could be /dev/ttyUSB1 …
But do be sure run lsusb and dmesg | grep … here you will see all the ports …
Hallo
Jeelink und CUL sind beides serielle Schnittstellen mit ihren eigenen seriellen Ports.
Jeelink sollte dem CUL demnach nicht in die Quere kommen.
Hast du den device Pfad in der culintertechno.cfg datei angepasst ?
Versuch mal über die Console lsusb und dmesg | grep tty auszuführen da werden dir dann alle beim ersten alle USB Geräte und beim zweiten alle Ports aufgelistet so solltest du den richtigen Port für den CUL finden.
Da Jeelink auf /dev/ttyUSB0 funktioniert könnte der CUL /dev/ttyUSB1 haben das ist aber nicht 100% sicher …
hallo thank for the answers i write the commands in the console
lsusb :
Bus 001 Device 005: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT 232 USB-Serial (UART) IC
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg | grep tty:
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ea00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=c78ac60c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.001246] console [tty1] enabled
[ 0.829625] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 3.884363] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
[ 3.885244] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
that was show on the screen.
Jeelink is ttyUSB0 and nano CUL is ttyUSB1 is that right?
thats now in the log:
2017-09-27 17:08:26.053 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=305, bundle=194/mvn:org.openhab.binding/org.openhab.binding.intertechno/1.10.0]: Unexpected problem updating configuration org.openhab.culintertechno
java.lang.NullPointerException
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding$1.open(CULIntertechnoBinding.java:64)[194:org.openhab.binding.intertechno:1.10.0]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:92)[196:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.CULLifecycleManager.config(CULLifecycleManager.java:74)[196:org.openhab.io.transport.cul:1.10.0]
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding.updated(CULIntertechnoBinding.java:147)[194:org.openhab.binding.intertechno:1.10.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1772)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
For posting prefornated text please use the Button “</>”.
You are using the entries from the OH1 .cfg file, which had the entries for all bindings. In OH2 you have a single for all bindings. That way the starting “bindingname:” can be ommited.
In your case remove the “culintertechno.” in each used line.
I have no intertecno devices so i cant say realy much about the binding it self but if we cant get ist to work
you also can trigger the devices directly so you dont realy need a binding (it make it easy but its not a a must have)
I have some devices with a unkown protocol and trigger it through the cul in raw mode
But lets get the binding to work:
The intresting point is:
So the binding cant read the culintertechno.cfg file !
Do you have made your changes in the file with a windows client ?
I had also sometimes problems with script and rule files edited in a windows client …
I have discoverd that the texteditor or wordpad somtimes reformat the text in the background when i saved the file.
As example i write:
stty -F /dev/ttyUSB0
echo “G0030af13403b1610097ee8” > /dev/ttyUSB0
And wordpad or texteditor will save it as:
stty -F /dev/ttyUSB0/p
echo “G0030af13403b1610097ee8” > /dev/ttyUSB0/p
The /p is a linebreak so the formating ist ok …
BUT when the system reads the file it will read the command stty -F /dev/ttyUSB0/p and get a error because with the /p its wrong.
Deinstall the intertechno binding and be sure the culintertechno.cfg is deleted.
Reinstall the binding to get a new untouched culintertechno.cfg file.
Go to the commandline and edit the culintertechno.cfg this way.
# Get to the directory of the culintertechno.cfg file
cd /etc/openhab2/services
# Type ls to see the files in the directory to get sure you are in the right one.
ls
#Open the culintertechno.cfg file with the nano editor.
#You can navigate trough the text (the cursor) with the arrow keys.
#When you done press strg+x
#Save changes dialog press y and return
#Filename dialog press return to save the file with the same filename
nano culintertechno.cfg
#To get sure everything is loaded reboot the server
sudo reboot
I am not 100% sure but i think the content of the file should be:
i installed openhabian on raspberry new
and just installed the intertechnocul binding
and configured it with nano
thats now my logfile
any new idea now ???
2017-09-28 18:34:33.197 [WARN ] [internal.serial.CULSerialHandlerImpl] - Can’t write to serial device serial:/dev/ttyUSB0
java.io.IOException: Stream closed
at java.io.BufferedWriter.ensureOpen(BufferedWriter.java:116)[:1.8.0_121]
at java.io.BufferedWriter.write(BufferedWriter.java:221)[:1.8.0_121]
at java.io.Writer.write(Writer.java:157)[:1.8.0_121]
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.write(CULSerialHandlerImpl.java:161)[185:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.writeMessage(AbstractCULHandler.java:265)[185:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.access$0(AbstractCULHandler.java:264)[185:org.openhab.io.transport.cul:1.10.0]
at org.openhab.io.transport.cul.internal.AbstractCULHandler$SendThread.run(AbstractCULHandler.java:55)[185:org.openhab.io.transport.cul:1.10.0]
just installed openhabian new, now i installed jeelink binding and the cul switched to ttyUSB1
the Log
2017-09-28 19:16:50.722 [WARN ] [internal.serial.CULSerialHandlerImpl] - Can’t write to serial device serial:/dev/ttyUSB1
but that is new Can’t write to serial device serial:/dev/ttyUSB1
In the description of the intertechno binding you can find the following:
When using a serial port, you may need to add -Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0 in your server startup.
This should open the serial port on server start but i cant recall/remeber the steps without try it on my openhab.
If you cant get it to work i will test it on monday.
But we can test the binding by open the port by hand
Its not a real solution because on a reboot the port will be closed again but for now it should work.
Get to the commandline und type:
# Setup the Port
stty -F /dev/ttyUSB1 38400 raw -echo
# Open the Port / Connection with a cat terminal in background
cat /dev/ttyUSB1 &
Now try it again … the port is open so the binding should work (if you dont get in other problems).
2017-10-02 08:36:45.207 [WARN ] [io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
2017-10-02 08:36:45.371 [WARN ] [io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
2017-10-02 08:36:45.380 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, baudrate = 38400
2017-10-02 08:36:45.384 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, parity = NONE (0)
2017-10-02 08:51:24.144 [ItemCommandEvent ] - Item 'test_sw3' received command ON
2017-10-02 08:51:24.215 [ItemStateChangedEvent ] - test_sw3 changed from NULL to ON
The cul is sending (blinking) but i cant test if he sends the right code i have no intertecno devices to test it …
So the binding standalone is working if you provide me with a link to your jeelink binding and one of your intertecno and jeelink items config i will test it with both.
hello and thx for the help that is strange i don’t now why but it is working now. I installed Openhabien on a new microSD Card. Install the Intertechno Binding from PaperUI, configured the cfg via nano.
Then i install the Jeelink Addon from https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.jeelink/2.2.0-SNAPSHOT/org.openhab.binding.jeelink-2.2.0-SNAPSHOT.jar
the same as the last time and it work. The jeelink and Intertechno CUL work.
But at this time i don’t use this settings
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyElero:/dev/ttyJeelink:/dev/ttyS0:/dev/ttyAMA0:/dev/ttyUSB0:/dev/ttyUSB1"
in the /etc/default/openhab2 File
and also don’t install
feature:install openhab-transport-serial
and now is all working.
i’m happy
thx
