I just installed the Jeelink Binding to my OH2 instance.
However, my TX25 Sensor is not found by the Device Search (via Inbox in PaperUI).
Even if I define the device manually with the according Hex-Code, it is considered as offline and does not retrieve any data.
Is TX25 currently supported by the binding and - if not - wold it be possible to add support?
The TX35 has a different data rate than the TX25. Which init command have you configured? If the interval is too long, the discovery might not get any readings.
