- Platform information:
- Hardware: odroid XU4
- OS: Ubuntu 16.04.4
- Java Runtime Environment: 1.8.0_161
- openHAB version: 2.3.0-SNAPSHOT 1254
- Issue of the topic: Exception while starting Jetty after update - that worked before my latest update, but now OH2 fails to start because of this exception
2018-04-14 15:44:59.617 [WARN ] [g.eclipse.jetty.xml.XmlConfiguration] - Config error at <Call name="addHandler"><Arg>
<New id="Rewrite" class="org.eclipse.jetty.rewrite.handler.RewriteHandler"><Call name="addRule"><Arg>
<New class="org.eclipse.jetty.rewrite.handler.ForwardedSchemeHeaderRule"><Set name="header">X-Forwarded-Scheme</Set><Set name="headerValue">https</Set><Set name="scheme">https</Set></New>
</Arg></Call><Call name="addRule"><Arg>
<New class="org.eclipse.jetty.rewrite.handler.ForwardedSchemeHeaderRule"><Set name="header">X-Forwarded-Scheme</Set><Set name="headerValue">http</Set><Set name="scheme">http</Set></New>
<New class="org.eclipse.jetty.rewrite.handler.RedirectRegexRule"><Set name="regex">/$</Set><Set name="replacement">/start/index</Set></New>
</Arg></Call></New>
</Arg></Call>
2018-04-14 15:44:59.637 [WARN ] [g.eclipse.jetty.xml.XmlConfiguration] - Config error at <Get name="handler"><Call name="addHandler"><Arg>
</Arg></Call></New>
</Arg></Call></Get>
2018-04-14 15:44:59.639 [ERROR] [rvice.jetty.internal.JettyServerImpl] - Exception while starting Jetty
java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl.start(JettyServerImpl.java:159) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl$Stopped.start(ServerControllerImpl.java:478) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl.start(ServerControllerImpl.java:81) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerFactoryImpl$1.start(ServerControllerFactoryImpl.java:164) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl$Unconfigured.configure(ServerControllerImpl.java:787) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl.configure(ServerControllerImpl.java:97) ~[?:?]
at org.ops4j.pax.web.service.internal.Activator.updateController(Activator.java:347) ~[?:?]
at org.ops4j.pax.web.service.internal.Activator.lambda$scheduleUpdateFactory$2(Activator.java:291) ~[?:?]
Caused by: java.lang.ClassNotFoundException: org.eclipse.jetty.rewrite.handler.RewriteHandler cannot be found by org.ops4j.pax.web.pax-web-jetty_6.0.9
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
at org.eclipse.jetty.util.Loader.loadClass(Loader.java:86) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.newObj(XmlConfiguration.java:785) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.itemValue(XmlConfiguration.java:1260) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.value(XmlConfiguration.java:1165) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.access$500(XmlConfiguration.java:276) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration$AttrOrElementNode.getList(XmlConfiguration.java:1393) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration$AttrOrElementNode.getList(XmlConfiguration.java:1368) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.call(XmlConfiguration.java:731) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:419) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.get(XmlConfiguration.java:700) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:422) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:302) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration.configure(XmlConfiguration.java:247) ~[?:?]
... 17 more
2018-04-14 15:44:59.698 [ERROR] [j.pax.web.service.internal.Activator] - Unable to start pax web server: Exception while starting Jetty
java.lang.RuntimeException: Exception while starting Jetty
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl.start(JettyServerImpl.java:197) ~[?:?]
Caused by: java.lang.reflect.InvocationTargetException
... 12 more
... 12 more
The jetty.xml configuration file is the same as in OH2.2
Any ideas, what to try? I’d like to keep the newest SNAPSHOT because of a fix in the Homematic bundle.
