I am using the latest versions.
- Openhab v3.0.2
- Android App version v2.17.0
In the log, I periodically get the following warnings
2021-05-25 15:51:50.744 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46471536 failed: null
2021-05-25 15:51:50.744 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:52:05.307 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472026 failed: null
2021-05-25 15:52:05.307 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:52:13.189 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46471941 failed: null
2021-05-25 15:52:13.189 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:52:18.006 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472149 failed: null
2021-05-25 15:52:18.006 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:52:21.233 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472205 failed: null
2021-05-25 15:52:21.233 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:52:25.303 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472253 failed: null
2021-05-25 15:52:25.303 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:53:09.611 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472416 failed: null
2021-05-25 15:53:09.611 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:53:09.645 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472417 failed: null
2021-05-25 15:53:09.646 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:54:00.086 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46472724 failed: null
2021-05-25 15:54:00.086 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:54:28.576 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46473291 failed: null
2021-05-25 15:54:28.576 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
2021-05-25 15:55:12.600 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 46473691 failed: null
2021-05-25 15:55:12.601 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: null
These warnings seem to occur consistently when accessing OpenHAB from a mobile device (android) with a remote connection. In addition, the app quite regularly gives the following error
Not sure if this is related, but these errors seem to go in tandem.
I have seen various links on the jetty error, but mostly on older versions without a solution.
Suggestions?
