I would like to join a piece of text with an item value eg: Temperature is XX and send it on Telegram. But I cant seem to figure out how to join texts in Blockly. Is this possible?
Just use the second text block. Clicking on the grear icon will allow you to join as many strings you want
Thank you for your quick reply. I cant get anything to attach to the “create text” block. Nothing happens when I click the gear icon and select join. What am I missing here?
After clicking the gear icon, drag and drop the item block into the join block. You can add as many item blocks as you like.
This also confused me at first!
Thank you for the help, when you first get it it it is obvious
